Question about Solis Master 5000 Espresso Machine
Hi H20 leakage. H20 build up under reservoir. Red light is on. Steve
  • 1,089 Answers
Hi
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it needs to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won't slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
Red light could be drip tray not seated, dredge drawer not seated. Its not blinking?
Posted on Apr 08, 2011
Won't build psi. When I purchased it, it worked fine. Tested to 5 ton. Let press sit 2 months and now it moves the ram but won't build psi
sounds like oil leaking back to reservoir under pressure when u pressure it up can u feel and hear like a hissing noise this is oil being passed back from ram u need to replace all seals,.....Easy to do
Sep 28, 2013 | Torin Big Red Hydraulic Shop Press with...
I have h20 man I use for swiming laps. At frist the player worked beyond my expectations. However, after charging and using it several times. It no longer charges. Nothning has changed. I plug it in...
Hi phd2,
This sounds like the MP3 unit has become defective. Please contact us at Intova by e-mailing kevin@intova.net or calling (808) 837-0074 and we will be able to help you.
Thank you,
Intova/SnapSights
Jul 30, 2011 | Snap Sights H20 Man MP3 Player
Hi, i need to put water in my Ford Ka because the light is flashing and havent done it for a while. There are three tanks under the bonnet, one says power steering fluid so i assume its not that one. Then...
Hi, I'm not familiar with the Ka,but did the light go out after adding water? There are only 2 car fluids that are red. One is auto transmission fluid and one is a type of coolant. The transmission reservoir is in the pan, so I doubt you could have seen red fluid in the transmission without pulling up the dipstick. You can also try disconnecting the level sensor on the reservoir that you added water to. If the coolant light goes on and off when you short the terminals in that connector together (use a paper clip), then that is the coolant reservoir. My guess is you got it right.
Jan 01, 2011 | Ford Fiesta Cars & Trucks
Hi Our H20 Mop is just over 12 months old and when we start it up the red LED light will not change to green nad will not steam up. When you run your hand down the machine you can feel a little bit of...
Hello
Our (POS !!!!) H20 Mop is just over 20 months old,suddenly became inoperative....
At startup,LED lites red,shortly thereafter changes to green,however NO steam out unit & an audable 'humming'
type noise comes from the unit.
Whatcha got ????
Alf
Oct 29, 2010 | Vacuums
The brake warning light in the IP is always on in my 1999 Chevy Silverado is always on. Any ideas what the concern might be?
Hi:
Your vehicle has a dual brake system, and the light usually indicates that one system has failed. First thing to check is your brake fluid level. If the front or back of the reservoir is low or empty, you have a brake system leak. check the insides of all 4 wheels to look for possible fluid leakage, as well as any other areas under your vehicle where brake lines run. My truck had a rear brake line rust thru, and it caused the same problem.
Good luck finding the problem!
Apr 21, 2010 | 1999 Chevrolet Silverado 1500
(I)(P) BRAKE light is on
hi from the uk assume you mean the brake warning light on dash which also comes on when h/brake applied ?? your brake fluid reservoir is situated on passenger side under hood/bonnet and is tucked just under the bulkhead below windscreen ? it is awkward for topping up but if you have a small funnel? and a short length of flex hose fitted to the funnel it is ideal for topping up reservoir via funnel with hose attached if reservoir is very low then you may have leakage from either pipe/s or wheel cyl's? this reservoir is also for the clutch hydraulics check the slave cyl for leakage too ? other than this ?? the drop in fluid level may simply be due to brake pads/shoes wear and as these wear low the fluid is displaced from reservoir to cyl's to compensate as pistons of cyl's move out taking up wear of pads/shoes?hope this explains ok ? may i suggest you check your pads/shoes for wear ? if you have not done so recently ? just for your own safety as well as others on the road best wishes
Mar 06, 2010 | 2002 Hyundai Accent
Solis Master 5000 Espresso Machine Logo
71 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
