Can only get sound through all 5 speakers if i set it to enhanced 5 stereo
  • 643 Answers
If your watching tv its usually only in 2channel stereo. Try a dvd with optical or coaxial to your receiver.
Posted on Apr 09, 2011
Sound problem with windows 7 32bit intel MB dg31pr
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen)
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC
Sep 14, 2011 | Intel DG31PR Motherboard
HK 2.1 analog system with Windows 7, worked flawlessly no problems, moved and reconnected system but no audio. Have tested speakers separately, reloaded drivers, have done a system reset, done an entire...
have you configured the speakers?
hope this helps you
Sep 05, 2011 | Harman Kardon Audio Players & Recorders
No sound. There is sound from the headphone jack on the external External I/O unit. However the only external sound that I get is from the subwoofer. No sound from the green mini plug and no sound from...
also
hope this helps you
Aug 27, 2011 | Creative Labs Sound Blaster Audigy 2 ZS...
I hooked up the boston speakers 4 plus wolfer and when I play music on You Tube, the rear speakers don't play. They work in the sound "test." They also work when I set the speakers...
the sound on utube is only stereophonic, hence you will get only stereo putput. If you play anything recorded as quadraphonic or above all your speakers will give sound output.
Jun 22, 2011 | Boston Acoustics MicroMedia Computer...
I cant get all 5 speakers to work without turning it to 5 stereo enhanced
Tv and Radio is usually only 2channel stereo. Try a dvd with optical or coaxial output.
Apr 08, 2011 | Yamaha RX-V463 Receiver
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
When listening to the fm tuner on my yamaha htr 6060, will all 7 speakers still make sound? i' having trouble getting sound from the other speaker connections other than the L and R front connection.
analog fm is broadcast in stereo you would need to use a simulated surround setting to have sound come out of your rear and mid surround speakers.
your manual says the default setting for fm broadcast is:
Radio Listening TUNER MUSIC ENHANCER
7ch Enhancer
Select this SCENE template when you enjoy FM or AM
radio programs.
make sure you unit is not in straight mode try pushing the straight button on the front of the receiver let us know if more troubleshooting is needed.
Cheers!
Feb 15, 2010 | Yamaha HTR-6060
Sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
Apr 22, 2008 | Audio Players & Recorders
Helo i have got a nokia 5300 black express music phone and i brought these mobile phone twin music speakers for them but i dont know how to set them up so please can u help me thnks
Equalizer
You can control the sound quality when
or diminishing frequency bands.
Select Menu > Fun & Apps> Media > Equalizer.
To activate a set, scroll to one of the equalizer
To view, edit, or rename a selected set, select
Not all sets can be edited or renamed.
Stereo widening
Stereo widening enhances the audio output of the phone by enabling a wider
stereo sound effect. To change the setting, select Menu > Fun & Apps>
Media > Stereo widening.
Mar 25, 2008 | Lands Phones
Surround sound from Sky +
Could be two things:
First you have to make sure the speakers are all active, there is a speaker button on the RXV361 front on the right I think but not on the remote, you need B setting for all speakers. You run the sound test from the set up menu.
or it could be that Sky is not showing the programme you are watching in 5.1 so you won't hear it from all speakers, you can force this by using the Music enhancer button of the RXV361 remote.
Hope that helps?
Sep 16, 2007 | Audio Players & Recorders
20 people viewed this question
 Grubhead
Grubhead
