Question about Car Audio & Video
Where does the illumination wire go - Car Audio & Video
  • 85 Answers
I usually just hooked it to the power.
Posted on Apr 08, 2011
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
Deh p8000r having problems with illumination won't get bright enough to see display
Hello! A resistive connection on the vehicle's illumination lead is the prime suspect...If you know the wire color for this signal, make sure it's a good solid connection to the P8000R's illumination wire...If you do not know the wire color send a comment with the year and make of your auto...
Guru........Saailer
Mar 29, 2010 | Pioneer DEH-P8000R
1998 buick park ave. rear window defroster not working. fuse is good, has anyone replaced the black box located next to rear window where element plugs into along with the antenna. element on window is not...
Rear Defogger Inoperative, But Heated Mirrors Operate Correctly
1. Connect scan tool. Turn ignition switch to RUN position. Turn rear defogger on. Using scan tool, display BCM
outputs. If rear defogger is being requested on, go to next step. If rear defogger is not being requested on, go to
step 10).
2. Ensure ignition switch is in RUN position. Remove rear defogger relay from rear junction block, located on center
right rear of passenger compartment, under rear seat. Connect test light between ground and defogger relay
harness connector terminal F3 (Brown wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 11).
3. Connect test light between ground and defogger relay harness connector terminal A2 (Red wire). If test light
illuminates, go to next step. If test light does not illuminate, go to step 12).
4. Connect test light between defogger relay harness connector terminals A2 (Red wire) and B3 (Purple wire). If test
light illuminates, go to step 13). If light does not illuminate, go to next step.
5. Disconnect rear defogger positive and negative feed bus connectors. Connect a jumper wire between defogger
relay harness connector terminals F3 (Brown wire) and A4 (White wire). Connect test light between ground and
positive feed bus connector terminal "A" (Black wire). If test light illuminates, go to next step. If test light does not
illuminate, go to step 8).
6. Connect test light between positive feed bus connector terminal "A" (Black wire) and negative feed bus connector
terminal "B" (Black wire). If test light illuminates, go to next step. If test light does not illuminate, go to step 9).
7. Repair open in Black wire between rear defogger and ground. Recheck system operation.
8. Repair open in Purple wire between rear junction block and heated backlight antenna module. Recheck system
operation.
9. Check for proper terminal contact at rear defogger connectors. Repair as necessary. Recheck system operation.
10. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
11. Repair open in Brown wire between rear junction block and instrument panel junction block. Recheck system
operation.
12. Repair open in Red wire between rear junction block and underhood junction block (located in right front corner of
engine compartment, between battery and strut tower). Recheck system operation.
13. Connect test light between defogger relay harness connector terminals F3 (Brown wire) and A4 (White wire). If
test light illuminates, go to next step. If test light does not illuminate, go to step 16).
14. Reinstall defogger relay. Disconnect BCM 32-pin Pink connector C2. BCM is located behind right side of instrument
panel, near rear of glove box. Using DVOM, check voltage between ground and BCM harness connector C2
terminal A3 (White wire). If any voltage is present, go to next step. If no voltage is present, go to step 17).
15. Repair open or short to ground in White wire between rear junction block and BCM. Recheck system operation.
16. Check for poor connection at defogger relay terminals. If connections are okay, replace defogger relay. Recheck
system operation.
17. Check for proper terminal contact at BCM. If terminal contact is okay, replace BCM. Recheck system operation.
Feb 25, 2010 | 1998 Buick Park Avenue
Power mirrors don't work. Which fuse controls this
Here is repair information from Mitchells:
1) Disconnect power mirror switch connector. Connect test light between power mirror switch harness connector terminal "A" (orange wire) and ground. If test light illuminates, go to the next step. If test light does not illuminate, repair open in orange wire between power mirror switch and righ rear power distribution center fuse block No. 1 (located under left side of rear seat).
2) Connect test light between power mirror switch harness connector terminals "A" (orange wire) and "J" (Black wire). If test light illuminates, check for poor connections at the power mirror switch. If connections are okay, replace power mirror switch. If test light does not illuminate, repair open in Black wire between power mirror switch and ground.
Aug 04, 2009 | 1997 Oldsmobile Aurora
What to hook the dimmer wire & illumination wire to
Those lower end Sony models dont use a dimmer or illumination. The display is constantly one brightness level.
Simply terminate or tape off those wires from the plug.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 17, 2009 | Car Audio & Video
Radio display light
To get the back light on you need to hook up the illumination wire to the ignition acc wire
Jan 10, 2009 | Clarion DXZ375MP CD Player
What is the orange wire on kenwood deck for?illuminate what?
the orange wire is for illumination it doesnt necassarilly mean that it illuminates your radio some vehicles it illuminates the dash lights or a/c controls so on and so fourth it may do nothing to your praticular car but others it does
Dec 28, 2008 | Kenwood KDC-MPV619 CD Player
Wiring problem with cd player and lights on car
If the unit is turning off when you turn the headlights on, check that you haven't used the illumination wire as ground.
The illumination wire will normally measure as 0V compared to chassis ground. When you turn the headlights on it will go to 12V compared to ground. With the headligts off, if you measure your constant power and switched power (aka 'Accessories') lines against the illumination wire you'll measure 12V and everything will seem alright. However, if you turn the headlights on and then measure again (now that the illumination wire has gone from 0V to 12V) you'll measure 0V, since the voltage difference between the 12V constant/switched power and the 12V illumination wire is zero - they are both now at the same voltage and no current will flow.
Once you find (or install) the correct ground wire and you should be right.
Dec 01, 2008 | Toyota Corolla Cars & Trucks
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
