My LOEWE TV has an intermittent fault. Sometimes when you turn it on the sound is there, but no picture. Other times it takes ages for the picture to eventually appear. Other times there is no sound or picture and other times it appears to be okay? Any ideas as to what is happening with it and is it repairable?
  • 8,457 Answers
Yes,this tv it is repairable,ur tv it is having a problems with a 1 or 2 long boards that are call the LCD inverter boards.These 1 or 2 long LCD inverter boards only job it is to provide the LCD screen panel a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD invert boards for the replacement.
Posted on Apr 08, 2011
I hav a loewe concept l32 tv whn u turn on by remote or manually tv turns on then switches off just b4 picture comes on
It sounds that the back-light ivnerter has the fault. Contact any service technician before confirmation.
Dec 02, 2013 | Olevia LT32HVE 32 in. LCD Television
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
My loewe acconda tv has horizontal red lines and
Any operation outside normal parameters would be considered "broken". Most broken TVs are repairable by a competent servicer for less than the price of a new one. A symptom like this however is the exception to the rule. It may very well be not cost-effective to repair. This is why most repair shops charge a bench fee for evaluation. If it is worth the peace of mind to know for sure then the investment of the minimum fee would be necessary.
Sep 05, 2009 | Loewe Aconda ACO9383 38" TV
TV MODEL 32PF9631D 2 YEARS OLD INTERMITTENT FAULT BECOMING MORE FREQUENT - PICTURE DROPS OUT LEAVING BLANK BLACK SCREEN (ALL CHANNELS INCLUDING FOXTEL) BUT SOUND REMAINS. TURNING TV ON AND OFF WILL...
You have problem with the power inverter, in you tv it might be part of the power supply, in which case you will need just one board. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
I have sound but no picture with my Loewe TV
Bad Ballast Board Call Encompass Parts 1-800-638-3328
Apr 13, 2009 | Loewe Articos 55 55" Rear Projection...
Tv beginning to flash green with horizontal white lines
From your description it sounds like a bad picture tube. The lines are called retrace lines. There is a small chance that a component on the small board that connects to the neck of the tube may be bad. Without model number information it is very difficult so say further. Some picture tubes can be re-jeuvenated with the appropriate machine ( at a TV repar shop)
If you feel adventurous and are careful you might try GENTLY tapping the neck of the tube and see if picture improves/goes out. If the tapping does change the picture it is definitely the tube
Mar 12, 2009 | Loewe ARC332 32" TV
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
PICTURE AND SOUND KEEP GOING OUT AND COME BACK FOR 30 SECONDS
One of the power supply areas are most likely going intermittent. This can be from cold solder connections on the circuit boards, or from some components failing due to age.
An experienced tech should be able to service your set, but it will be expensive for the time involved. Sometimes these types of faults can be very time consuming to resolve.
Jerry G.
Nov 21, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
Electro Med Services...
