Question about Bosch Refrigerators
My Bosch kgn33v00gb fridge/freezer is up the spout. The fridge is not cold at all, but freezer is fine.
  • Bosch Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 08, 2011
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Fridge section is warm freezer is cold fan not working can hear the motor from thr fan but fan is definately not spinning. BCH KGN33V00GB
Hello Tonytonz953,
I understand that you are needing to change the fan on your refridgerator. The fan is loacted in the freezer section and has an outlet that blows in to the fridge compartment. You can order the fan at the following link http://www.ransomspares.co.uk/parts/search/fan-/bosch/fridges-freezers/kgn33v00gb%2f06/b/c/m/ this is the cheapest on that I could find and the cost is 75.85 pounds.
Thank you for choosing FixYa.com
Justin
May 11, 2011 | Microwave Ovens
Bosch Fridge, Freezer OK but Fridge won't cool
Well nobody came up with any other options so I guess it's just defrost a "nonfrosting" fridge every three months or so, just like the old days.
No progress here then in spite of advances? in technology.
Oct 10, 2009 | Bosch Refrigerators
Suspected broken fan prevents top fridge section cooling down
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Jul 29, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge not cooling, freezer fine
You might try removing and ohming out the door switches before you remove the fan motor. for fan motor operation the switch should read open on the NO to C and closed on NC to C with the switch out of the fridge. push and hold in the switch and the opposite readings should be observed IE closed on NO - C and open on NC - C. look closely at the switch for these letters.
If you have an electronic control system with an led or lcd display a magnetic switch may be employed and this would do both operations with a magnet close to the switch acuator.
Jun 20, 2009 | Bosch Refrigerators
Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Mar 14, 2009 | Bosch Refrigerators
Faulty Fridge freezer
I suspect you may have a faulty compressor! Do you notice if the compressor starts?
Feb 05, 2009 | Bosch Freezers
FRIDGE NOT VERY COLD - ABOUT 15 DEG C, FREEZER OK
relies on air flow between fridge and freezer but is regulated.
fault is probably ice build up on top of evaporator in freezer. remove back panel inside freezer and check. also check the air ducts are not iced up
Nov 19, 2008 | Bosch Refrigerators
We have the Bosch kgn34x60 fridge freezer and the fridge wont stay cold. The dial is turned to 5. Any ideas on what might be the problem????? had it less than ayear and the freezer is fine
I have this model and am having the same problem. Bosch don't want to know as it is out of warranty.
This means that a perfectly good freezer has to be thrown away because the fridge won't work properly.
Don't buy Bosch.
Jun 01, 2008 | Refrigerators
Refrigerators Logo
445 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
