Question about Car Audio & Video
After jumping a dead battery on a 2005 ford focus the radio will not play in drive or reverse. It plays fine in park or neutral, and has power at all times.
  • 4,803 Answers
I have seen the PRNDL switches on these vehicles cause all kinds of problems including erratic radio operation, engine stalling, transmission erratic shifting, engine control fault codes, etc. I had one that kept losing the programmed stations on the radio and the radio would cut in and out while driving. I have not figured out exactly how the PRNDL switch fits in to all of this with the radio. I believe it is shorting the class 2 data circuit or something. I would look there for a solution to your problem.
Posted on Apr 08, 2011
I have a 2004 ford focus and when I put it in reverse all power is lost like a dead battery. I jump it in neutral and proceed to put it in reverse and it dies and won't start until I jump it again. I...
must have a short in the reverse wire connected to trans. moving shifter causes the short which kills. prob a bare spot on the wire should be on side of trans
Feb 23, 2015 | 2004 Ford Focus
97 buick century was running after jump started, when put in reverse it died and wont start when jump start, no chimes or lights come on at all
Dangerous practice to try & jump a near dead battery
Always try charging a battery, that is only a couple years
old & not run down more than two or three times
If the battery is dead & reads less than 12 volts, have a parts
store test it or just replace it.
Jumping a cars battery is not a fix for anything,so I fail to
see how your lost & have not addressed the battery issue,
so you can continue on with other testing,if needed
Sep 24, 2014 | 1997 Buick Century
2003 Ford Focus won't go into reverse
You can check the fluid level of a transmission only while the motor is running while in park or neutral (wheels blocked). Remove the rear dip stick (transmission) and wipe it with a rag, reinsert it completely. Repeat the procedure and note the level, which should be between or in the hash marks (towards the end of dip stick) and add accordingly.
If the level is okay you will have to check with transmission shops and the Ford dealer for quotes ( and check on Google ). The problem you have is either a transmission or computer problem.
Mar 09, 2014 | Cars & Trucks
Focus 04 no power
either the battery is completely dead or the alternator do not charge.
Sep 15, 2012 | 2004 Ford Focus
HOW DO YOU KNOW IF YOUR MOTOR MOUNTS ARE GOING BAD
HI, one of the easiest ways to check is to have someone apply the brake and HOLD it while shifting the car from park reverse neutral and drive and back down. As they do this you can watch the engine for any excessive movement or jumping.
Aug 27, 2010 | 2003 Ford Focus
2005 expedition radio only plays out factory subwoofer what could the problem be
WELL SOUNDS LIKE AUDIO AMP SECTION IN RADIO IS DEAD... RADIO POWERS REGULAR SPEAKERS.. ALSO SENDS A SMALL SIGNAL TO AN EXTERNAL AMP THAT DRIVES THE SUBWOOFER.. START LOOKING FOR RADIO
Aug 31, 2009 | 2005 Ford Expedition
Ford Mondeo - ?Battery not getting charged after jump starting!
YOUR BATTERY SOUND LIKE ITS DEAD. CHECK BATTERY VOLTAGE SHOULD BE 12.5 VOLTS IF NOT TAKE IT TO YOUR NEAREST AUTO ZONE OR ADVANCE AUTO.LET THEM TEST IT LOAD TEST IT.WHEN BATTERY IS CHARGED OR REPLACED.WITH ENGINE RUNNING ALTERNATOR OUT PUT VOLTAGE SHOULD BE 13.5 VOLTS TO 14.5 VOLTS.IF NOT HAVE ALTERNATOR CHECKED.IF ALL GOOD YOUR ALTERNATOR FUSE / FUSE LINK BLOWED OR YOUR ALTERNATOR WIRES IS DAMAGE.OR DRIVE BELT SLIPPING.REMEMBER TO TURN OFF RADIO BEFORE DISCONNECTING NEGATIVE.BATTERY CABLE.IF YOU DONT YOU WILL LOSE RADIO CODE.RADIO WILL NOT PLAY.
Aug 30, 2009 | 2002 Ford SVT Focus
My car radio stopped working
You more than likely burned the fuse for the car's radio and will likely need to be replaced.
Jun 15, 2009 | 2005 Ford Focus
Car is completely dead, like somebody shot it dead! No sounds, no light, can't shift out of park into neutral or anything....everything completely dead...no warning whatsoever!
Always clean the battery terminals before jumping. An extremely dead battery may not accept a jump as it serves as a 'buffer" instead of helping. If you do get it started, charge battery with a battery charger then have alternator and battery tested for proper operation and check belt condition and tension as well.
May 29, 2009 | 2002 Nissan Altima
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
