Question about Hotpoint Dishwashers
My dishwasher keeps leaking underneath when running model hda200ua
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Apr 08, 2011
My frigidaire dishwasher model #FFBD2403LW0B serial#TH13718959 leaks when it is running.seems to be leaking from underneath not from the front door.
how about putting the washer on some sort of stand so that you can look from underneath and then running it. use a light and observe where the leak is
Apr 11, 2017 | Frigidaire Dishwashers
GE Potscrubber,Quiet Power dishwasher leaks while running
Check to see if the door baffles are intact they are little black rubber things in the front on each side of the tub. the pump seal could be leaking underneath. the wrong detergent (dishwashing detergent) could have been used.
Oct 08, 2014 | Dishwashers
Frostfree freezer leaking from lower front
From what you have described, without a model number, it sounds like the unit is leaking from possibly going into a defrost cycle. Check to see if you have any ice build up that is now melting or "slushy" in that general area. Water tends to run along the nearest plastic ridges and parts til it can escape underneath.
Jul 31, 2012 | Electrolux Frigidaire Professional Series...
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electroluxe dishwasher starts and once water runs it quits working and all the lights on the display start blinking and it won't work. Any ideas?
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Danby dishwasher leaking from underneath
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Jun 14, 2009 | Danby 22 in. DDW399 Free-standing...
Hear the motor running, no water in dishwasher
I thought I would fix this myself - but hubby took a look, wiggled a few wires and said 'there's your problem'. The water valve would not open because a connecting wire was loose. It was the kitten after all - I'd better pop that panel back on.
Feb 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Simpson Silencio 850 leaks - the water doesn't seem to stop filling. Replaced all seals, but it keeps filling until it leaks and we have to stop it manually.
Hi, I've just purchased a 2nd hand model of your dishwasher. mine actually leaks from the black lining underneath. I've just patched it with some Sellys bathroom sealant. I don't know more about your problem but sounds like it could be something not timing out to stop the water, maybe buy a new 1 :P
Sep 11, 2008 | Dishwashers
Plumbing connection to dishwasher leaking
Remove bottom panel and run dishwasher while monitoring it. A large leak may be from a hose off at pump underneath. Mice can chew holes in hoses too.
Nov 15, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dishwashers Logo
379 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
