Question about Sennheiser PXC 350 Headphones
I can not get them to charge or turn on. They are new and never been used and I have them on the charger but I can't seem to get any power to the headset. When I push the battery button it doesn't light up or turn on
  • 6,771 Answers
I would take it back for exchange, there is nothing more than can be done because this is clearly a manufacture defect.
Posted on Apr 08, 2011
Will not charge and actually seems to discharge when plugged in to auto charger
Charge the unit overnight with a high power usb charger, 2A or above. If it turns on after that, check your auto charging cable. It should have a red led that illuminates if it has power. If it does not, then it is either the cable or a fuse blown in your car. If the gps still does not turn on after chargning overnight, you have a batter issue. Amazon sells battery kits.
Apr 06, 2015 | Garmin nuvi 2599LMTHD 5" GPS with Built-In...
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
Camer will not power on
If your battery does not seem to charge, then you need to carry out some tests on the device, the battery and the charger. First you insert the battery into another cam corder then you try to charge, if it charges, then it means the battery is okay and if it does not charge, then it means the battery is bad and need to be replaced.
Then i will advice you take the charger and try to charge another device to see if it will work, if it works, then it means the charger is alright but if it does not then it means the charger is bad and need to be replaced.
Finally, test the camcorder by plugging a well tested charger and battery into it and trying to charge it, if it does not charge then the problem is from the camcorder.
Feb 12, 2014 | Canon MVX20I Mini DV Digital Camcorder
The red light is always on, and it doesn't seem to be charging. Its almost brand new.
Same thing started happening to me. The red charging light was initially going out but then after a few days use started staying on. I assumed that the battery was damaged and bought 3 new batteries but the red light is still staying on when I charge the new batteries.
I suspect that the mains charger I was using (same voltage but not the recommended charger) has perhaps damaged a component inside the EFLC1003 unit which is now not letting the power through to charge the battery.
Dec 30, 2010 | E-Flite 1s 3.7v Li-po Battery Charger Mcx...
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
Feb 15, 2010 | Olympus Mju Tough 8000 Compact Digital...
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
I can't get the charging light to turn on.
I have the same problem, after our building had a electricity problem. The electricity spiked when the utility company came to fix a problem. Several adapters in our apartment seem to be affected. Like my Kone, my dirt devil detailer had the same problem: charging light didn't come on, and while it charges, it only gets up to weak power. I got a new charger/adapter and when I plugged it into the base, the charging light was working again.
Jun 24, 2008 | Dirt Devil KONE Hand Vacuum MO213BLU...
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Sennheiser PXC 350 Headphones Logo
62 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
