Question about Dryers
My whirlpool dryer LGR4634EQ3 has started clicking while running recently. Any suggestions as to what might be the issues?
  • Dryers Master
  • 2,696 Answers
Do you mean like a bad roller or something like that as the drum is spinning?if so you can by a kit with the belt,two rollers a pulley and the clips to hold the rollers on.i'll look up the price and part number for the kit and send it to you.
Posted on Apr 08, 2011
  • Sal De Apr 08, 2011
    the kit part number is 4392065 and it's around 35 dollars.copy and paste this site it will help you out...http://www.youtube.com/watch?v=xGIG8Wo5-...
My whirlpool dryer WED5800SW0 won't start. It is receiving power because the timer switch still makes the clicking sound before you start the dryer. I have had recent issues of the pin not engaging...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Model # LGR4634EQ3 is turning but it is not getting hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Whirlpool Dryers
Whirlpool lgr4634eq3 gas dryer-runs on low heat or heat fails to work-sometimes. Timer is new; plenty of gas, the ignition element obviously works
i would check your gas valve coils
they are probably weaking or at least your hold is
but i would replace both
they sit right on top of your gas regulator behind the ignitor
two littly tube like things
Oct 09, 2009 | Whirlpool Dryers
Dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Jul 24, 2009 | Whirlpool Dryers
Dryer flame goes on and then off
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 05, 2009 | Dryers
Whirlpool LGR4634EQ3 not heating
most likely your coil set is bad. is it turns on once, but then doesn't ignite again, your coil set is overheating and not working. it will need to be replaced. Joe
Dec 02, 2008 | Whirlpool LGR3624JQ Gas Dryer
Gas dryer/ whirlpool
well your generating heat which is a good sign, either there is a blockage in your venting() most likely source of issue!) but you say ou replaced, i would then look to replacing the valve coils, 279834, about 20 bucks, easy to replace... its possible that they open the valve upon start up allowing heat, but after being on 20-30 min they overheat and no longer open not allowing heat to generate..
Apr 03, 2008 | Whirlpool LGV4634JQ Gas Dryer
Gas dryer not heating up
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
Mar 29, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
