Question about Compaq Presario 700 470024-192 Notebook
While charging my laptop , mouse pointer cant work and while it. why?
    Guru:
  • 868 Answers
Hi avinamit,
I saw your question and I think I can help you with your concern.
you mentioned that when you connect your charger/Adaptor tp you laptop that the touchpad will not respond or move, I believe that your machine may be experiencing a small amount of ground from the adaptor to the touchpad, here is what we need to do,
  • First we need to turn your Laptop OFF
  • Once turned Off, remove the battery from your Laptop and unhook/remove the AC adapter/Charger as well.
  • Once the Battery and the Adapter is remove from the system, press and hold down the power button for 10-15 seconds this will drain any power left in the system, by doing this we will be starting the machine up with a new set of power coming from the Charger.
  • Once the power is drained is done connect the Adapter back to the machine and the battery try to power your system ON and check if the touch pad will work now with the adapter connected to your Laptop.
this may help you with your concern about the touch pad not responding when the charger is conencted, but still if the issue still exists then most probably the machine is grounded from the charger to the motherboard thus causing malfunction to some of your system devices.
thanks I hope this helps.
Posted on Apr 08, 2011
  • Safalta Aug 09, 2011
    Your suggestion is not working with me. If my machine is grounded from the charger to the motherboard thus causing malfunction to some of my system devices, then how could i recover it?
Cursor not showing up
Well the touchpad driver could be erased or a virus may have damaged it.
You should go to Acers website and then support and download drivers and get the right touchpad driver.
Install it and see if it works.
Use TAB to navigate for now. or use mouse keys.
This means keep pressing shift really fast and accessibility option will show up.
Use tab and space bar to navigate to MOUSE TAB and select Mouse Keys and hit enter.
Done for now you can use the numpad to operate the cursor.
Second option is to go out and buy a USB mouse.
Worst case scenario: Touchpad is damaged and needs replacing.
Or simply a cable got disconnected and needs reconnecting by taking the laptop apart
Get Your Laptop Mouse to Show Up if It Disappears
Using a laptop is as efficient as a desktop computer to complete tasks, use the Internet and talk with friends on a daily basis.
If your laptop's mouse cursor disappears, there are various tricks and solutions available to help get your mouse pointer back to resume your work and current computer tasks within minutes.
And this can be accomplished without the use of software applications or advanced computer skills.
Press "Ctrl" + "Alt" + "Delete" and choose "Task Manager" if your mouse pointer becomes available, pressing the keys simultaneously.
This will allow you to close any open programs that may be causing issues with your mouse pointer.
Plug in an external mouse to allow the computer to attempt to find the device, prompting the mouse pointer to appear which may solve the problem or allow you to temporarily work with a mouse pointer.
Reboot your computer by pressing and holding the laptop's power button for a few seconds.
This will reset your laptop's current open settings and most often allow your computer's mouse pointer to reappear.
Upgrade your laptop's video and graphic card drivers (if available) to ensure the mouse pointer disappearing or flickering is not a hardware issue.
Select "Start" > "Control Panel" > "Hardware and Sound" > "Device Manager" to view your current graphic and video settings.
Visit your device manufacturer's official website to download the most current version of your drivers.
http://support.microsoft.com/kb/198614
Aug 05, 2013 | Acer Computers & Internet
My external mouse quit working on my Acer Aspire 5100 laptop.I have tried plugging it in to all the ports. It says USB device not recognized.
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 24, 2011 | Acer Aspire 5100 Notebook
I cant get my i.t.works mouse to connect to my laptop?
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 17, 2011 | Computers & Internet
While charging my laptop , mouse pointer cant work and while it is running on batteries mouse pointer works
hi
remove the battery from your notebook -- use the Ac adapter only
will the mouse pointer work ? are you using an attched wirelss mouse or the palmrest pointer ?
let me know what OS you use -- and if its mouse you use, what model ?
look forward to helping you resolve the issue !
Nov 03, 2010 | Dell Inspiron 1525 Notebook
Pointer Mouse froze in the middle of the screen Please help i cant get it to move so i cant use the Computer Thank you Very Much . Bill
if there is a light above the touchpad it should be blue if it is orange it is turned off push the button by the light it will go blue and the mouse will work.
Jun 14, 2010 | Toshiba Satellite M35X-S161 Notebook
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Asus eeepc 701 with xp mouse pointer stops working intermitently
It probably just freezes due to too many tasks. After all that laptop doesn't have a lot of RAM, it's a great device though, i have the same one.
Feb 24, 2009 | ASUS Eee 4G Notebook
Cant get Pointer to move
First try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Then if that doesn't work try
Hope this helps you. Bud
Feb 19, 2008 | Dynex Wireless Optical Mouse DX-WOM100
Laptop mouse
Go to Start --> Control Panel --> Mouse.
Click on the Pointer Options tab and adjust the slider for the pointer speed.
Regards,
Javabytes
Nov 16, 2007 | HP Compaq Presario V2000 Notebook
It's WIRELESS. The receiver is powered by USB. The mouse needs batteries. AAA in most cases! If batteries test ok in a remote control...they should have enough for mouse.
Nov 12, 2007 | Dynex DX-WOM20 Mouse
Compaq Presario 700 470024-192 Notebook Logo
302 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
