Question about JVC Audio Players & Recorders
I need connector cord for sp-pwa10. where can i get it.
    Top Expert:
  • JVC Master
  • 74,136 Answers
Hello
You haven't specified about which connector cord you wants. I thinks it will be a power cord. Power cords can be selected according to the power input socket of your device, and has no specifications. Choose the best one you can buy, and of good brand. That is all. Ok.
Posted on Apr 08, 2011
How to change a fuse on a korg Sp-250
There is no fuse inside SP250. If the unit can't power ON,there maybe damage to the adapter,adapter cord/connector,or broken fuse inside the adapter.
If adapter is in good condition, then the damage is inside SP250.
The possibilities are on regulator section.
Check all parts in this section (figure 1).
Also maybe there is a broken soldering joints at DC input socket.
change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-0.jpg change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-1.jpgchange-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-3.jpg
Jun 01, 2014 | Korg SP-250
Power cord with correct voltage
Most power cords for TV, will meet this reqirement.
Jan 22, 2014 | Samsung SP-R4232 42 in. Plasma HDTV
My ricoh aficio mp 2000 have the error sc 542 what i can do to sorve this.
Reset the code via SP Mode (I will not tell you how to enter SP Mode, you must research that). Once you are in SP mode enter System or Copy SP and turn off the machine to reset.
The code is actually referring to a thermistor problem in your fuser, regardless, if your machine is under maintenance request service (obviously, I do not think it is under maintenance or you would not be asking). Other than that, once this thermistor completely flakes out your machine will be rendered useless.
P.S. ALWAYS GET MAINTENANCE ON YOUR COPIERS, quit being cheapskates.
Source: Ricoh's Tech Support Goose Guide. Ricoh Qualified Copier Technician.
May 02, 2011 | Computers & Internet
Where do i find a connector cord for my powered subwoofer model no. sp-pwm606
There are a few on eBay. Search for "JVC THM505 cable" and check the 'include description box'.
If you need the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
Mar 16, 2011 | JVC SP-PW100 Subwoofer
How to change spark plugs on a 2005 vstar 1100
2005 V-Star 1100 Classic - Spark plugs
While someone may be able to change SP's w/o removing the gas tank, most normal humans will find doing so impossible. Removing the tank is easy. Here are the steps/tips for changing your SP's
1. remove the passenger seat - 1 screw at the rear and pull toward the rear of bike.
2. remove rider's seat - 2 screws and pull the toward rear of the bike.
3. turn gas valve to off; some gas will leak during the next steps, so have a wad of paper towels or your wife's best nighty to sop up the gas (maybe a tablespoon).
4. pinch the hose clamp that secures the gas hose to the gas valve body and slide the clamp away from the valve body stem.
5. pry the hose from the gas body stem; I used a very slim flat screwdriver. This is where you mop up the gas.
6. remove the two screws at the rear base of the gas tank; ALSO - there is a small black plastic connector on the front side of the battery case that connects the tank to the battery case. The head is round, about the size of a nickel. Push the center pin in the head of this connector down a bit with an allen wrench, for example. Then, pull the connector up and out. S/B easy. If you drop it into the chassis guts, good luck.
7. slide the tank toward the rear of the bike. Easy! There is an electrical cable between the bike chassis and the tank, so you cannot, or need not, "remove" the tank to the floor or workbench. I "balanced" the tank across the chassis over the battery box and secured it in place with some bungee cords. Secure the tank as it will slide off.
8. Tip: the rear SP is on the right side of the bike as you sit on it. The front SP is on the left side of the front cylinder.
9. Remove both plastic head covers, one over the rear SP and one over the front SP, pulling straight out away from the bike. They are held by rubber grommets only, but they were not easy for me to pull out. They are plastic, so if you pry them, be careful! Yamaha probably charges $50 for a new one (cost to mfg = 17 cents).
10. use the SP socket and the box end wrench in the bike's tool kit to remove the plugs. It's a bit tricky, but not bad.
Putting it all back together is not bad. I did it and am not a mechanic. Just take your time. Doing it yourself will probably save you $60 or more. Good NGK plugs at the auto parts store were $2.50 each. Probably $6.95 at the Yamaha dealer.
Oct 21, 2009 | 2005 Yamaha V Star 1100 Classic
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
I need to know how to wire 110 to 220 on a hayward sp-1605-z1 pump motor
The Hayward superpump is factory set at 220.
If you need to convert it to 110, all you need to do is take a screwdriver and remove the cap on the back of the motor. There are three prongs in the motor and a black jumper. The jumper connection needs to be disconnected and moved from The top and middle postion prongs, to the middle and lower prong. The ground wire (green) still connects to the same spot (usually a green bolt grounding lug). If using a Haward SPX1250wa (110 Cord) connect it to the pump Black wire to black connector/White to white. The Hayward cord comes with pre-attached terminal connections that makes it easy to do.
Once the cap is re-attached you should be good to go.
Oct 08, 2009 | Plumbing
European GBA SP concerns
I have 1 question. why would you buy a sp from france when you can buy one here?
Dec 04, 2007 | Nintendo Game Boy Advance SP Console
TROUBLE IN LP540
Check for internal fuse on power module, you will have to open the case.
Make sure power cord is removed. Be carefull capacitors tend to hold a charge long after power is removed. I have a LP640 ....big brother to this one. If you open the case the warranty is voided so think about it first. the fuse could be on the circuit board and will look like a small solid green resistor or it could be a full sized fuse in-line with the wires coming from the power cord connector. I have seen the inside of a LP390 with the fuse behind the power inlet connector. Good Luck
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
Can't switch the music on
Press SP-PHONE * 7511 SP-PHONE to turn the holding music on Press SP-PHONE * 7510 SP-PHONE to turn the holding music off
Aug 17, 2007 | Panasonic KX-T7630 Corded Phone
208 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
