Question about Kenmore Front Load Washer
Washer - washes (tub tumbles in both directions, drains, but does not spin. Checked belt and it is in place and tight enough. Can hear motor running but drum does not spin. Model 44252
    President:
  • 2,468 Answers
The "hall-effect" motor sensor in the drive unit is not reading the ramp speed from 400+ RPM's and higher and not letting it to operate through the complete wash cycle,
Posted on Apr 08, 2011
I have a GE Mod. WJRE5550H1WW washer. It appears that all the functions work except the spin cycle. Is there something I can do ? The machine is just over two years old. Thanks for...
The drive belt may have been broken, worn, or has slipped off. Reset the washer then restart a new cycle and check if it will tumble or not. The belt is indeed not in good operating condition should the washer seem to complete the wash cycle but does not tumble or spin.
Unplug the washer for 2 minutes then plug it back in. Open and close the lid seven times to reset the motor and the inverter.
The inverter on the top of the motor flashes a code to indicate a fault. Take the washer front panel off to access the motor and the inverter and see the blinking LED. Look into the seam where the top meets front panel. There is a clip on each side; push a flat head screwdriver into the clip to release it Pull the top of the front panel and slide it up to remove it. Check belt and the LED for the code. Black powdery substance at the base of the washer is a sign that the belt is worn; replace it.
May 25, 2010 | Washing Machines
Will not spin fast, when it spins you can rase lidmby pass door switch and stop itfrom spinning
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Oct 22, 2008 | Roper RAS6233KQ Top Load Washer
    Washer fills, cycles, drains, but won't spin or agitate. I took off bottom panel and belt is in place and appears tight. The pulley moves easily by hand and has about an inch of play which I assume is...
    Noting that you verified the belt is in place and that the motor turns freely.. If the unit fills and drains but does not spin or agitate there are only 3 things that can cause the problem
    1. The lid switch
    2. The timer
    3. Wiring
    The most common failure the lid switch itself
    Item 388 this link
    http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=25484225&pkw_=basket&model_id=5217498&NewWindow=1
    You should hear and audible click as you just open or close the lid, No click = no wash or spin but will fill and drain. You can try actuating the switch yourself to see if it will spin. If you need more help repost here and will go from there.
    Jan 16, 2010 | GE Profile WPRE6100G Top Load Washer
    Model: WWSE5240G0WW Tub does not spin but can hear motor running. Rest of cycles appear normal. Nut underneath the agatator is tight.
    Does it drain? If not your pump is bad. If it does drain you need a belt if it is a belt driven washer.
    Oct 17, 2009 | Washing Machines
    My washing machine wont rinse spin or drain
    Hi..
    If your washing machine wont drain, you need to check this following:
    • Inspect the drain hose for kinks
    • Test the timer control
    • Test the lid switch (some models)
    • Inspect the water pump
    • Inspect the drive belt (belt drive only)
    • Inspect the motor coupler
    If it wont spin check this
    • Test the centrifugal switch
    • Test the water level switch
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    It won't drain If your washer won't drain, check these:
    It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
    To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
    Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
    If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
    It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
    It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
    • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
    • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
    It doesn't spin If your washer won't spin, check these:
    It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    Thanks !!!
    Regards
    PCmania
    Jul 10, 2009 | Kenmore Washing Machines
    SAMSUNG WD-J2155R DOES NOT TUMBLE . It takes in water, heats the water up but the tumbling process does not activate.
    May 06, 2009 | Samsung WF203ANW Front Load Washer
    Will not spin,
    Washing machines may drain but doesn't spin because of the following reasons:
  • Thank You
    Jan 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Washer will not spin
    Tip the washer and try to turn the transmission pulley by hand counter clockwise.
    If the pulley will not turn you likely have a seized drum bearing.
    since your washer pumps out the water but doesn't spin, check these:
    * The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    * The motor coupler may be broken. Most washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    * A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    * The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    * The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    * The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    * The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
    Sep 09, 2008 | GE WSXH208A Front Load Washer
    Roper(whirlpool) washer will not spin model # ras7133kq1
    check the motor coupler between the motor and the transmission
    Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
    Kenmore Front Load Washer Logo
    136 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
