Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Cleaning I can clean the grid but how do clean the bulbs?
  • Anonymous Aug 11, 2008
    how do I claean the Ionic Breeze GP?
  • deenee Nov 14, 2008
    Thank you very much. It really helped.
    Scholar:
  • 62 Answers
Cleaning it is described in the product's documentation and in other Fixya solutions such as this one:
http://www.fixya.com/support/t154553-ionic_pro_sizzles_crackles_when_turn
As for the bulb, I just put a squirt of Windex (or whatever glass-cleaning liquid is handy) on a paper towel and carefully wipe the surface of the bulb. Make sure it is 100% dry before you put the bulb back in. (To get the bulb out, after removing the grill, gently grip the bulb and give it 1/4 turn either direction. To replace, do the opposite.)
Posted on Nov 13, 2008
It keeps making a static sound. and it lights up with the sound because there is a small shock that happens ever 10 seconds in the back above the filter
That happens when the electrostatic grid needs to be cleaned. There should be instruction for cleaning the electrostatic grid in the owner's manual.
Nov 05, 2013 | Air Purifiers
Every time I turn on my Ionic Breeze the "needs cleaning" light comes on within a few minutes. I clean the grid but this keeps happening. What do I do now?
I have a ionicbreeze silent air purifier the "the cleaning light comes on within a few minutes . I have cleaned the grid but this keeps happening. What do I do?
Jan 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
I have an ecoquest fresh air purifier and the end of a red wire was corroded so I replaced the end with a new one, but the unit doesnt seem to be producing any ozone smell or sanitizing. It seems as if...
That corrosion is oxidation for the lug connecting the grid plate.Metal contact fingers make contact on the plates metal grids.The same corrosion exists on those metal contact fingers and the plate itself. Clean the fingers,ensure good connections as the other wire connector spade for the other contact finger is probably compromised. You might de-oxidize the plate by soaking in pure white ammonia.At any rate,I agree about the quality of the machines and you might be faced with a small parts order from eco-quest.Do include the plate, a bulb and the bulb starter. I run 5 of these in a commercial setting and they are fairly enjoyable to work on.
Jul 25, 2009 | Ecoquest Fresh Air Living Air Purifier
I have a breeze AT, fan is the only one that's working, I tired to clean and visually check if there's anything out of the ordinary but nothing that I could tell, what seems to be the problem?
make sure the bulb and starter are working....do you see blue light emmissions from the inside of unit? That and the grid plate are the major players in this machine.clean plate,soak in ammonia and clean contact fingers that can get corroded including the female spade connectors for the wiring.
Jun 25, 2009 | Ecoquest Breeze AT Living Air Purifier
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Feb 22, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Red light stays on
I had the same problem: Had cleaned it inside, taking off both grids, washing wire, etc. Still the red light blinking would come back on after a few minutes. So here's what I did next:
Take off the grids on both sides. Make sure the grids are clean with water and paper towels (lots of black) On the unit itself, wipe out the metal sides and all the plastic. Then, here's the KEY,
get out your computer cleaning canned AIR and blow it into the open unit and blow the air on both of the grids too. I first used a hairdryer to blow it out, but the canned air is much stronger and I got all kinds of little black particles out with it.
Put it up and down 3 times, plugged it back in and WALAA! The unit is back to working perfectly and no red light has come on again!
I'm sure this will work for everyone if you just get the canned air and blow out the unit and the grids too even though you've cleaned them!
Sep 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Metal grid cleaning
You must press both the timer and reset buttons together had same prob Ezio
Feb 26, 2007 | Surround Air XJ-3800 Air Purifier
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
94 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
