Question about Winix PlasmaWave 5000 Air Purifier
Winix PlasmaWave 5000 air cleaner dust sensor level indicator shows HIGH level (red) all the time. Never lowers while the unit runs. How do I get it to working?
What air filter do i buy for a replacement?
http://www.amazon.com/Winix-115115-True-Replacement-Filter/dp/B002QUZJAS
Jun 26, 2014 | Winix PlasmaWave 5000B Air Purifier
Where can I find replacement filter for Kenmore 85500 air cleaner
I just went to the chat site for sears parts and asked them to find one. They ordered part #119010 Filter CATEGORY: Plumbing and Heating
PART NUMBER: 119010
which comes up to this page... http://www.searspartsdirect.com/partsdirect/part-number/119010..... I did order it through them.. I hope this helps anyone else looking for a replacement filter for the Kenmore #85500 with filter #85501.. With the link above you can order it online.
Feb 14, 2013 | Kenmore EnviroSense 85501 Air Purifier
Model s1871sharper image room purifiler. keeps blinking that it is not clean when i just cleaned it
Just check to make sure none of the wires at the front of the unit broken and shorted to an adjacent plate.
Wash the electrode unit with an acidic cleaner like Formula 409, and let it dry, and dust out the cabinet with clean compressed air if you have a source. While this will not alleviate all the red indicator indicators, it will address most of them. The others, you may just decide to live with because the air filer is still filtering/ionizing even if it does indicate it needs cleaning..
Sep 28, 2012 | Air Purifiers
When I'm in my bathroom and showering the light turns red- what does this mean- Mold?. moisture?
The simple answer is moisture. If you have a bathroom exhaust fan, be sure to run it during and after you're showering. Typically, for a bathroom exhaust fan to reduce the moisture properly, it should remain ON for at least 15 minutes after your showering is complete,
Hope this helped to answer your question.
Apr 23, 2011 | Winix PlasmaWave 5000 Air Purifier
I just replaced my filter for the winix 5300 model and the replace filter indicator does not seem to turn off. Are there any solutions or procedures as to how i should go about this matter?
Remove the front cover and locate the FILTER RESET button below the DUST SENSOR level display indicator lights. Press and hold this button for 3 seconds until the unit beeps and the REPLACE FILTER indicator light goes out.
Apr 02, 2011 | Winix PlasmaWave 5000 Air Purifier
Dust filter has indicated extreme level of dust for several days making the fan stay on high. any way around having it professionally repaired?
- Remove the top two screws from the control panel.
- Remove the control panel. Be careful not to pull to hard as there is a ribbon cable taped into place.
- If the ribbon cable is taped, remove the tape and set down the panel as to not put weight on the ribbon cable.
- On the top left side of the unit (behind the dust sensor), there is a small box that is held in by a screw and plastic clips. Remove the screw and put tension on the clips so you can remove the box.
- there should be two holes in the box (one on each side), use a cotton swab and alcohol to clean outside and inside the box. I reached inside with the wet swab as far as it would reach.
- While you are in there, take some time to remove as much dust off of the front panel and anywhere else it may be.
That did the trick for me.
Dec 24, 2010 | Kenmore EnviroSense 85501 Air Purifier
I've replaced the filter. why won't the red replace filter light shut off?!
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Sep 03, 2010 | Winix PlasmaWave 5000 Air Purifier
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Filter not clicking or emitting clean air smell and dust is flowing like filter is not energized
MAKE SURE THAT YOUR CELL(S) ARE CLEAN ... CLOSELY INSPECT TO SEE THAT THERE ARE NO BROKEN IONIZING WIRES (THE SMAAL STAINLESS-STEEL WIRES THAT ARE BETWEEN THE COLLECTOR PLATES). MAKE SURE POWER GOING INTO UNIT TO IS "OFF"!!! ... NOT JUST THE SWITCH ON THE UNIT. THEN TRY THE FOLLOWING: THIS AIR-CLEANER THAS A AIR-FLOW SENSOR THAT SOMETIMES GETS CLOGGED ... IT IS INSIDE THE TOP CONTROL PANEL. THERE SHOULD BE A DIAGRAM UNDER THE CONTROL BOX COVER PLATE TO ASSIST YOU LOCATING THAT SENSOR. MAKE SURE IT IS CLEAN. THE HIGH-VOLTAGE TRANSFORMER BEING BAD USEUALLY WILL SMELL LIKE BURNT WIRING. AND WILL LOOK BURNT. MAKE SURE YOU SEE NO LOSE WIRES ... SOME TIMES THE SPARK-PLUG LOOKING WIRE GOING TO THE CELL(S) CAN BURN OFF ITS CONNECTOR. YOU CAN CHECK THE DOOR SAFETY SWITCH TO MAKE SURE IT IS MAKING CONTACT WHEN HANDLE IS PROPERLY CLOSED. GOOD LUCK ... HOPE YOU HERE THAT ZAPPING SOON ... BY THE WAY ... IF YOU GET A POWER LIT ON ... GIVE THE RETURN-AIR DUCT A SLIGHT BANG ... IF IT IS WORHING IT SHOULD SNAP CRACKLE AND POP FOR A FEW SECONDS. MAKE SURE YOU SEE NOTHING (HAIR?) LYING ACROSS THE PLATES OR IOMIZING WIRES ON EACH CELL IF YOURS HAS TWO. ELECTRIC AIR CLEANERS ARE ONLY GOOD WHEN THEY ARE KEPT CLEAN ... PET HAIR IS A CONSTANT MAITENCE PROBLEM AND CELLS SHOULD BE LEANED EVERY TWO WEEKS. FOR BEST PERFOMANCE. Joe_Rex 40+ years Hvac Contractor (retired)
Apr 29, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Winix PlasmaWave  5000 Air Purifier Logo
50 people viewed this question
Top Winix Air Purifiers Experts
Are you a Winix Air Purifier Expert? Answer questions, earn points and help others
