Power sub plate amp replacement
I have an older JBL PSW1200 powered sub. you probably already know about the amp of this unit having issues. i actually had this sub for over 8 years now before the amp went out on me, but i like the sound of the sub. i can't find a GOOD answer to my question of what size amp to replace it with? i see people say the amp unit is 150W, another 200W, another 300W ??? i've been looking on a couple websites:
http://www.mcmelectronics.com/browse/Amplifier%20Modules/3831187
http://www.partsexpress.com/webpage.cfm?Webpage_ID=3&CAT_ID=43&ObjectGroup_ID=505
i would love to be able to find an exact match, but i know that's probably not possible......could you please let me know what is a 'good' amp to replace the defective one with? thank you soooo much!!!
amp dimentions: L x W x D = 12" x 8" x 3.25"
rick
rick.bailey@bt.com
    Scholar:
  • 144 Answers
Why not try to find a used working similar model sub instead of replacing the amp? any amp different than the one built in will provide a sligtly different sound.
Posted on Aug 08, 2008
How do I connect jbl psw1200 sub?
Well, it depends what you're connecting it to....
If it's a stereo receiver or Hi-Fi amp, then the speaker cables that would normally go direct to the front L & R speakers now connect to the sub's L&R speaker OUT sockets. Then you need two extra lengths of speaker cable. These go from the receiver's speaker outs to the sub's L&R speaker IN sockets.
Connecting to a surround receiver, just use the phono/RCA cable from the receiver's "Sub Pre Out" to the white phono/RCA labeled Low Level IN.
Aug 30, 2014 | JBL Audio Players & Recorders
Have a PSW-D112 sub woofer that needs a new amp. Repair facility says original amp took a catastrophic power surge and it's toasted. JBL says repair parts not available. Please advise on source for...
Go to Parts Express and buy the Bash 300w digital subwoofer amp.It fits almost exact except it is one inch shorter.Just use mdf to fill the space and this amp will outperform the original.I have done this and it's not really difficult,pretty straight forward.
They usually sell for around $149,but they have sales often around $99.Good luck.
Oct 28, 2010 | JBL PSW-D110 Speaker
I need a new power amp for a JBL PB12 Subwoofer
Alf, when there is no parts available you have to start looking at local non authorized repair shops that will inspect and repair the board instead of trying to source a replacement board.
This can be very difficult and could make for alot of expensive deposits. Running out of parts is an ongoing problem with all electronics and sometimes replacement is the most cost effective option.
Cheers,
Kevin
Feb 09, 2010 | JBL PB12 Subwoofer
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Nov 10, 2009 | JBL PB10 Subwoofer
Psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Dec 28, 2008 | JBL PSW1200 Speaker
E250P Not powering on... chirping noise
I had the same chirping issue with the sub. I found a document that talks about replacing the C5 capacitor for a 47mfd type instead of 470mfd. This solved the chirping issue however I still experience an intermittend issue with the power on indicator flickering off and on. Anyone hear of the fix for this?
May 12, 2008 | JBL Northridge E 250P Subwoofer
Jbl 12 subwoofer
Good chance it's the power supply; a capacitor there, the large one, may have gone. These things age and when they go, there's noisy power to the amp circuit and ... well, that may be what you're hearing. You should check your audio wiring, too. That woofer could be picking up a 60Hz hum from the AC mains and amplifying it. Maybe you can try another spkr on same cables and see if hum is in your woofer or elsewhere. Good luck.
Sep 10, 2007 | JBL PB10 Subwoofer
1,695 people viewed this question
 Grubhead
Grubhead
