Question about GE Advantium 120 Convection/Microwave Oven
Kenmore elite advantium microwave
The door is hard to open. You really have to pull hard. Is there a way to adjust it?
  • GE Master
  • 8,872 Answers
GE Customer Service is here. They may refer you to their Answer Center.
Posted on Aug 12, 2008
Adjust the door to enable easier opening
Apply a LITTLE BIT of grease to the door latches.
Dec 23, 2014 | Kenmore Elite Microwave, Model...
Door Switch- SCA2001 FSS 02 GE Advantium 220v
a parts diagram would be useful here..let me go see what's available
Apr 01, 2008 | GE Advantium SCA2000B Microwave Oven
Door hard open
It sounds like the hinges are worn out or broken. Probably cheaper to buy a new one that to fix the old one.
Oct 15, 2014 | GE Advantium 120 Convection/Microwave Oven
Kenmore elite micowave still runs after door is closed with no time on menu
The door switch may be adjusted. If not then it will have to be replaced.
Aug 18, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Advantium 120 blew breaker when door was closed. I reset breaker and it worked for three weeks. Breaker is blown again...when i open the door and reset breaker it works, but as soon as you close the door...
I'd suspect the interlock monitor switch is stuck, or its mounting bracket is out of adjustment. This is designed to blow the fuse if you try to run the oven while the door is open. The switch is supposed to open when you close the door. This switch is replaceable, but you should have this oven repaired by a professional. There are lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't done correctly.
Mar 20, 2010 | GE Advantium SCA1001SS Convection /...
Kenmore Elite Advantium 120, model # 363.63693301, display working, exhaust fan and exterior lights work, won't heat in microwave or convection mode. What could it be?
You probably just have a bad primary interlock (upper door switch) or its mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
For more on door switches & mounts, see:
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
But if you need any cosmetic parts,
enter your full model number at the Sears parts site.
Jul 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
I would suggest you look over this excellent tutorial.
If this is not close enough to your oven to help, please reply back.
Oct 05, 2008 | GE Advantium 120 Convection/Microwave Oven
Door hard to open on GE Advantium
That's odd.
I think you're just going to have to examine it while opening and closing the door.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
That can help. Good luck.
Aug 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Repair or replace?
MICROWAVES ARE MADE TO BLOW THE FUSE IF THERE IS A POSSIBLY OF DANGER--THAT'S A GOOD THING...SAFTY SWITCHES ARE MADE TO CLOSE(SOME UN-CLOSE) WHEN THE DOOR IS OPEN AND SHUT AND IT SOUNDS LIKE YOU DO HAVE A LITTLE DOOR PROBLEM---THE REPAIR SHOULD BE FIXABLE AND MAYBE REASONABLE,,MY GUESS COST-WISE ,,,75.00,,OF COURSE ,IT ALL DEPENDS ON THE SERVICE COMPANY--TRY AN INDEPENDANT SERVICER (NOT SEARS,ETC) GOOD LUCK TUNICA
Jun 10, 2008 | GE Advantium SCA1000H Convection /...
GE Advantium 120 Convection/Microwave Oven Logo
381 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
