Question about Brother CE5000 Computerized Sewing Machine
New CE5500PRWBrother. having trouble threading the top. the thread take up lever does not protrude enough to thread the thread through the hole. have read and re-read the manual. can't figure out what to do.
  • Brother Master
  • 1,133 Answers
Have you tried hand winding the fly wheel towards you to bring the take up lever to the top of its cycle to thread it?
This does sound strange as most computerised machines the machine would stop at the top of the cycle so this should not be necessary. Is it possible that it has been damaged in transit.
Best solution is probably to ring the shop where you purchased it and talk to their sewing machine person about it, certainly if it is a fault it should be under warranty.
And if it is just a case of you learning how to use the machine, a reputable shop should always be happy to answer a question or spend five minutes showing you again how to thread the machine.
When I purchased my last machine, I think I spent an hour there having a demo first time, then went back again with questions and my fabric to test sew myself before buying.
Posted on Apr 08, 2011
For the dressmaker II, the first bobbin, I got through step 1-5 but where the does step 6 go BECUZ that's really trippin me, PLS tell me. And the instruction is not clear at all, I don't understand it
Hi Vicky, I hope this helps you:
1. Remove the slide cover plate by sliding it toward you, and lift
up the bobbin and the bobbin case from the machine.
2. Put the bobbin pin into the hole on top of the hand wheel and
place an empty bobbin on the bobbin pin (spindle).
3. Lift the large spool pin from the back of the machine and
place the spool of thread on the large spool pin.
4. Place the bobbin winder tension clip into the hole in the back
of the machine.
5. Pull the thread to the left and pass it through the bobbin
winder tension disc.
6. Insert the thread through the hole in the bobbin from the inside
out and leave about 3" of thread out. (ensure that the hole on the bobbin is facing upwards)
7. Hold the end of the thread and start the machine, either by
pressing on the start button or the foot control. After the
bobbin winds a few turns, stop the machine and cut the thread
close to the bobbin. (Cut the thread end that is protruding from the hole at the top of the bobbin).
8. Start the machine again and continue winding until the bobbin
is full or the quantity of thread is enough for your needs.
9. Stop the machine and cut the thread. Remove the bobbin from
the bobbin pin.
10.Take out the bobbin pin from the hand wheel and push back
the large spool pin into the slot in the back of the machine.
Good luck :)
Jun 21, 2015 | Euro-Pro Dressmaker 998B
Elna tavaro
Could be a host of things to trouble shoot,
Needle, is it sharp and right size for fabric type? Sharp for woven or ball point for knit
Is threading up correct, you don't say which model but this is link to threading a Star Series SU
http://youtu.be/xEn3dNeiTqs
Is bobbin wound nice and smoothly, also should be Elna 7hole bobbin which is slightly dished and holes one side. Always wind with holes on top and load same way, when you draw thread off bobbin will rotate anticlockwise. Also check bobbin thread has clicked into tension spring. You will hear it click in. If you lift upwards and thread comes free then try again, push down on thread with finger tip till it clicks into spring.
Is top tension dial clean between discs, always thread with presser foot raised so thread goes into tension fully. Is thread in take up lever, and through all thread guides?
Top tension dial on 5
That's my regular trouble shooting list, hope it helps or add more details
Apr 18, 2014 | Elna Sewing Machines
Singer quantum XL-150 how do i thread this machine?
All Singer models would have arrows/numbers to guide your top threading from the spool pin to top thread guide, for most machine start from your thread spool pin, to a thread guide follow arrow down then up into the take up lever and down to the needle thread guide then into the needle hole. Assuming you have wind and install the bobbin thread into the bobbin case, turn your hand wheel towards you makes the needle bar goes down,keep on turning till the needle bar is fully up again, pull the end of the top thread to pick out the bobbin/bottom thread. With your material/fabric under the presser feet, apply the presser feet lever down, you are ready to sew.
Dec 24, 2013 | Singer Quantum XL-1000 Computerized Sewing...
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Jan 10, 2013 | Sewing Machines
I have a brand new Brother XR1300, but I can't
use the "needle Up/Down" button to raise the needle - when i first got it i turned the wheel by hand, but it was never in the right position
Dec 29, 2012 | Sewing Machines
I have a husquavarna 875. the thread is jamming in behind the bobbin. i have re threaded, changed the bobbin and cleaned the bobbin area of any lint or thread. any ideas?
Is the top thread coming down in the rotary hook and then jamming? if so, review the top tension and top threading and see if you've missed a thread eye somewhere, particularly the thread take up lever or if the thread is actually under enough tension on top.
You can test the top tension by lower the pressure foot and then pulling the thread downwards after its feed through the tension device, it should feel firm but give to a firm tug.
If this isn't happening, try rethreading it, cleaning it out and adjusting top tension to get it firmer. Generally 4 is a good setting so just make sure it hasn't been adjusted inadvertently.
There is also good trouble shooting help at http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Troubleshooting.htm which may help you to identify what's causing this problem. Check also that the bobbin is the correct one for your machine, and in and rotating in the right direction. But if it is the top thread jamming into the bobbin race its probably top tension.
Aug 02, 2011 | Husqvarna Sewing Machines
The take up thread lever will not come out far enough for me to thread sewing machine
that is because the thread lever on these machines does not come out, you have to place the thread over the top of the arm and it will find the ****.
then continue to thread your needle.
there is no hole to thread it is very easy when you have done it once, just follow the instructions in the manual carefully.
Mar 05, 2011 | Brother XL-2230 Mechanical Sewing Machine
Have a new machine and trying to thread for the first time. Thread take-up lever does not move into a high enough position for me to thread cotton through the eye. Help please.
You should be able to turn the hand wheel (on the right side of the machine) towards you and you should see the take up lever on the top left. It does not stick above the machine.
Let me know if you need more help,
Chris
Jun 02, 2010 | Brother LS-2125 Mechanical Sewing Machine
Machine is not pulling the bobbin thread
1. Put in a new needle, make sure the flat side is facing the rear of the machine.
2. Take the thread off the top of your machine. Rethread the top of the machine, with the presser foot in the up position. Make sure you thread the take up lever. The take up lever is the lever that disappears and then reappears near the top left of the machine. The thread goes to that lever after the tension unit.
3. Put your tension dial on 5 or 6
4. Make sure your bobbin case it threaded properly, when you pull on the thread once it's up through the hole in the needle plate, you should feel "slight" resistance.
5. When you turn the Hand wheel on the side of the machine, turn it only towards you, never towards the rear of the machine. Try to pick up the bobbin thread now, if it still doesn't work, you need to take it to a service tech.
Oct 17, 2009 | Husqvarna Sewing Machines
Threads caught in the take up lever wheel
looking at the top left side you should see a hole large enough for a screwdriver and through that hole there is a screw. Loosen the screw and the left side cover should come off.
sewman7
Jun 07, 2008 | PfaFF Creative 7570
Brother CE5000 Computerized Sewing Machine Logo
49 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
