Question about Vacuums
I knew my pin but then I have another atm card with a different pin so now i dont know both of the pins can you help me please
  • 2,510 Answers
The only people that can help you with a problem like this is you banking institution. Go and see them.
Posted on Apr 08, 2011
The direct drive head does not fit...we don't know why, please explain as we have just opened the box it is brand new.
If there is a problem of any kind with the physical parts then it is recommended to take it back to the place of purchase.
Alternatively, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Oct 26, 2015 | Dyson V6 Absolute Bagless Cordless Hand...
My little yellow steamer heats up normally but no steam comes out. Can anyone help please.
There is probably lime built up blocking the hole, try taking a needle or safety pin and push into the hole on the sprayer head. Shut it off first and remove the top sprayer part push pin through and then run backwards through the hole you might not be able to see anything come out unless you do it over a paper towel or coffee filter.
Dec 20, 2013 | Scunci 52001 Handheld Steam Vacuum
Electrolux Unirapido not working green light flashes when start button is pressed!
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Apr 15, 2013 | Vacuums
How to put click pin back in craftsman snowblower
Open pin, Separate pin from circle. Insert pin into hole of drive wheel, the close circle unto pin.
Feb 15, 2013 | Craftsman 155443 Click Pin
On a Faema Due expresso machine: Viewing the circuit board from the component side, with the two 0.1 uf caps on the left. The two pins on the left of the eight pin connector are completely burned from the...
The descripion you have send is only for the board. We need to know also how is the machine.
Is the machine working good up today and you have descover this after a fault?
If there was a fault what was that?
We need some of this information in order to get the whole picture and history of the machine.
Jul 27, 2011 | Vacuums
I forgot my parental pin and question. I also dont know who to call. what do i do
May I get the make and model # to help you more with your problem.
May 03, 2011 | Vacuums
Carpet brush turning on and off during vacumming
If the problem is only with the brush, and the vacuum motor is working all the time, then the most likely cause is a poor connection between the upper and lower parts of the machine. As you will know, the two parts can be separated easily and (especially if you do that often) the two little flat pins that make the electrical contact can become damaged. So check the pins, and the sockets they fit in to. If they are not visibly damaged, good contact can sometimes be restored by VERY SLIGHTLY bending the pins.
If you are able to check for electrical continuity between the pins in the brush part, then do so. If your machine has done a lot of work it may be that the so-called "carbon brushes" in the motor are worn out and are no longer making good contact so will need to be changed.
I hope this is helpful. If you need more information just post a reply and I'll see what else I can do. Please remember to rate this response. Good luck!
Feb 05, 2010 | Sebo Felix Fun Bagged Upright Vacuum
G4 plug
Does not matter much. Any will do.
Oct 24, 2008 | Kirby G4 Bagged Upright Vacuum
Handle foot pedal release U6425-900
I have the exact same problem. I can't even open the unit up. Let me know if you found anything out. I have searched the web and can't even find a service manual to purchase ! Thanks.
Apr 08, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
