Question about Kenmore 54501 Dehumidifier
Unit turns on for about a few seconds and shuts off. bucket full light stays on. Micro-switch is ok what else could that be
    Brigadier General:
  • 4,736 Answers
Possibly., the unit turning ON vibrates the bucket in such a way, that it loses contact with the safety switch and the unit shuts OFF. If the dehumidifier is not sitting level, it would cause the bucket to shake more than usual. In addition, if you haven't cleaned the filter recently, I would suggest that you do that. A dirty or clogged filter causes the unit to struggle and if it is to much to handle, it will cause it to shut OFF. Before you attempt remove the filter, turn OFF the Master ON/OFF Switch and Unplug the unit. Be sure you do it in the order I listed.
Hope this helps you further to troubleshoot and solve the problem.
Posted on Apr 08, 2011
I have a zenith zd300yo. the machine turns on for approximatly 2 seconds then shuts down. The bucket full light blinks on and off and the diplay screen shows 01.
If the bucket is not really full, it usually means the when the bucket was remove and reinstalled, it wasn't installed properly. Turn the unit OFF and unplug it. Remove the bucket and look inside of it, to see is there is a float valve. If so, it may be stick in the UP position. Jiggle it to make it return to DOWN position.
If your unit does not have afloat valve, reinstall the bucket, making sure it fit's "squarely" into the bucket holder. Once installed properly, the bottom of the tank should not tilt down at all. And it should be making contact with the bucket removal safety switch.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 24, 2011 | Dehumidifiers
It will not turn on. Is there a reset button? It worked fine for over 5 years, then it just quit.
Hi, Sounds like the circuit board...they often will just do that...IF you can get one it will be half the cost of a new unit...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 19, 2011 | Maytag M7DH65B2A Dehumidifier
The bucket full light stays on while it is empty. the humidity control doesn't change. the unit is not going on.
There should be a switch that is activated by a float lever that if tripped will make the bucket full light stay on, and will prevent the unit from going on.
If this light is on when the bucket is empty, maybe try to jiggle the float lever, or investigate why the switch is activated when the bucket is empty.
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Jun 04, 2010 | Dehumidifiers
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
Empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
May 31, 2009 | Whirlpool AD65USL / AD65USM Dehumidifier
Maytag electronic dehumidifiers full light stays on
Take out the bucket and locate the "full" switch in the upper right of the area where the bucket slides in. With the unit on, try pushing it in and see if the "full" light goes off.
If so, that switch is fine - if not try to adjust if and replace it if required. Those are generally micro-switches and firms like Radio Shack would have if your appliance parts dealer does not.
Aug 03, 2008 | Maytag M7DH45B2A Dehumidifier
Kenmore 54501 Dehumidifier Logo
105 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
