Question about Creek Destiny integrated Amplifier
I have Creek Destiny Integrated Amplifier.My problem is: amplifier not work.Left chanel not work.Power transistors are burned. Question is:-which model of transistors is?Or,which substitutes ? Thanks!
How do you kill a captain level 121?
Your question makes no sense in this forum.
Oct 27, 2014 | Creek Destiny integrated Amplifier
I shorted out the speaker wire going to sub and now the amp doesnot work
You have probably blown the internal power supply fuses in your amp or the speaker fuse in the amp. The chances of blowing your sub are slim.
The internal fuses can sometimes be hard to find. They aren't usually intended for the user to change. DO NOT replace them with higher amperage fuses if they blow after you replace them as there has been severe damage caused to the circuitry. Also, don't replace them with higher amperage fuses because you think that this will let you get more power out of the amplifier. This won't work, and you will end up blowing your expensive output devices.
Oct 05, 2014 | Audio Players & Recorders
One side dead
hi zm_16dec,
Right chanel fully dead , output transistor burnedout ,
Without knowing the make and model of your amplifier
all i can advise is to replace the unknown part number of
the transistor.
Look for the working left channel output transistors and
replace the bad transistors in "pair". These may include
other components but check on it as well.
Check the speaker system, especially where that channel
is connected.Inspect speaker wires or cable up to the speaker
itself.
Amplifier wont blow without reason.It could be from the wirings,
speaker or volume settings of the unit.
Thanks for choosing Fixya for assistance!
Dec 24, 2012 | Audio Players & Recorders
My problem i lost transistors for power for car amplifier audio apache i need numbers for transistors
There might be still other power transistors left, same part number
for the power inverter ( IRLZ43N on some ).
Except for the Main Amp that have Complimentary Pair
check for possible burnt or open resistors , too
Jul 23, 2012 | Audio Players & Recorders
Creek SE 5350 one channel without sound
I think you will find that the fault is either a dry joint somewhere (have you moved it recently?) OR more likely a transistor. It might be caused by one getting very hot! Thus shutting down and coming back on when cool.
The best way to track this troublemaker down is to spary each transistor (in the left channel only don't bother with the other or Power section) with Servisol Freezer spray. Wait for the thing to play up then spray -one at a time- if it pops on you have got the bugger! To make certain apply a soldering to it and it should act up again. Spray again to confirm.
Apr 11, 2010 | Creek Destiny integrated Amplifier
Amp powers up. the right channel works fine left not at all
If you didn't find any burned parts that would mean one of the buffer amplifiers before the power amp could have died. They could either be transistor based or opamp based. They are fairly low power so they will not explode like the output transistors like to do. Contact rockford, they should be able to send you a schematic. Let me know I will try to help you through it.
Dec 14, 2009 | Rockford Fosgate Punch 401S Car Audio...
Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Feb 02, 2009 | Audio Players & Recorders
59 people viewed this question
Top Creek Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Creek Audio Player and Recorder Expert? Answer questions, earn points and help others
