Question about Bissell 8975 CleanView Bagless Upright Vacuum
Belt keeps comeing off, would like belt area.diagram of brush and drive. The drive doesn't have a gear, only a shaft...(phreaug@northernmi.net)
  • 436 Answers
Here is a link to the manual:
http://www.bissell.com/assets/0/132/134/228/5a40e038-7412-463d-9c1e-796440d9ad2c.pdf
I hope its what you are looking for. if not, let me know.
Thanks
Please rate FIXYA
Posted on Apr 08, 2011
The main belt on my hoover model u6634-900 windtunnel keeps comming off the motor shaft
  • A list of things to check (unplug vacuum FIRST):
    1. All contact surfaces for belt are clean of build up, that can push belt in one direction
    2. Brush roller is not flip end for end (the pulley on the motor shaft should line up straight with the worn area of the brush roller).
    3. The guard on the bottom (covering the belt and brush sides) is clean and free of build up.
    4. The ends of the brush roller are free of build up and the bushings that slide in the end are inserted in the correct direction, this can cause the brush roller to set at an angle and cause the belt to slide in one direction.
    5. You have the correct replacement belt, I have found the wrong belt placed in the packaging for my vacuum at the factory once before (check manufacturers website).
    6. If the brush roller is extremely worn, it could be time to replace but this is very unlikely.
    7. Rotate the motor shaft by hand and see if there is any wobble, the pulley could be on crooked or bearing has failed causing slop in the motor shaft.
Jun 21, 2014 | Hoover Vacuums
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 7901-1 Cable that turns brush ripped. Where can I get a new one and how do I replace. Also when I turn to the high trafficsetting fluid doesn't spray out but it does on water only. Spinny...
If I'm understanding your question concerning cable/belt ,you can go to a bissel parts supplyer on line and order what you need ther are two bels that are envolved inthat area. The one that turs the brush is the belt with the teeth/cogs on it. To replace it there is an accesess door on the right hand side,using a screwdriver gently pry up on the door,which will expose the belt area .The belt that you are replaceing will attach on the brush then strech it to the point of the motor shaft, since one belt remains it's a simple prosses of elimination.the rest of your question is some what envolved I've requested info about the same area. So you might want to keep a look out for the answer tohow realign smartmix valve
Hope this helps.
Jun 17, 2011 | Bissell 7901-1 ProHeat Scotchgard Upright...
Kenmore upright Model 116 31912101 Brush doesn't turn. Little red reset pin doesn't move.
Something is jammed in it or the belt is bad.Turn it upside down.You will see 4-6 screws.Remove the screws and the plate they are holding.Now the brush is exposed.The belt hooks on to the brush and a small wheel on the other end.Remove the brush and belt.Make sure the area is free of debris.While you have it off,replace the belt.
May 16, 2011 | Kenmore 31913 Progressive Direct Drive...
Majestic filter queen vacums
Your belt is either stretched or the wrong size or the brush bushings are worn and allowing the brush to wobble or the motor is loose in its housing. You need to check all.
Rotate the brush and try to wobble it from the pulley end.
Flip the belt inside out, it if appears cupped, cracked or shiney and slips easily on and off the brush it is stretched. Generally this unit needs anew belt evrey 6 months, broken or not, they get hot and stretch. Do not buy a new belt by matching size, a worn belt can be 20-30% oversized and not broken but totally useless.
The motor shaft should be cleaned with W/D 600 grit sand paper. Motor should have no wobble in the shaft
Sep 09, 2009 | Vacuums
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Drive belt ; whirlewind litespeed.
There is nothing but the motor shaft. The belt rides on the shaft and around the brush assembly on the other end. The belts fail if the brush assembly gets jammed, for example from a rug ot debris. If this occurs you should immediately turn off the unit,unplug the power cord, and clear the jam. Also occasionally cleaning the brush and being sure the bearings on each end turn freely will help prolong belt life. The brush assemblies also look to be available. lysager@gmail.com
Jan 25, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Hoover U6634-900 self propelled, brush belt keeps coming off.
unfourtunatly it could be the height of your carpet also using on area rugs could cause it to do that too. check the brush roll and make sure it is spinning freely.
Aug 29, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Oct 20, 2007 | Bissell 8910 ProHeat Clear View Upright...
Brushes stopped working
go to thehooverstore online. search for your machine and click on your diagram. it will show you how the belt goes on the drive.
Sep 11, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 8975 CleanView Bagless Upright Vacuum Logo
160 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
