Need to clean inside of JVC TV 56P775 - Televison & Video
  • 643 Answers
Use a vacum cleaner. You want to pull out the dust not push it in with compressed air.
Posted on Apr 09, 2011
How to clean inside screen of jvc big screen tv?
I would not even attempt that If I was you on this model, what is dirty, spider webs or what?
Dec 08, 2012 | JVC HD-52G786 52" Rear Projection HDTV
JVC TV: Model # HD61Z456 61 inch - what is the modet number of the bulb that I need to replace. I have no picture on my screen.
The bulb part number is: TS-CL110UAA. Take out the bulb and look inside from the front side. Visually inspect any physical damage inside. If it looks clean, lamp might be good
Jan 22, 2010 | JVC HD-61Z456 Television
Brown picture
you can clean it, take front off and clean with a mild detergent. if this tech has any relatives in the auto mechanic industry stay away and keep your women away!!
Dec 11, 2009 | JVC HD-52G786 52" Rear Projection HDTV
I have a 56" JVC rear projections HD ILA tv.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
May 07, 2009 | JVC Televison & Video
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
My JVC 56G787 is dark and bright is turned all the way up
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | JVC HD-56G787 Television
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
JVC HD-56G886 56INCH REAR PROJECTION TV
I fixed it!!!! If you can open one of the sides (on the JVC there is a little door with a screw), then you can clean the projector lense in the middle on the bottom. It kind of looks like a big light bulb. It seems there is just dust on the glass that is projected onto the screen. We had a big gray spot and cleaned it with a damp glass cloth and Ouila! It disappeared. I scored MAJOR brownie points with my husband for this one! He wanted to replace the TV!
Sep 25, 2008 | JVC HD-52G786 52" Rear Projection HDTV
MY JVC HD56G786 TV
If the Mirror broke while the TV was sitting upright, the pieces of glass got down inside the light engine and the cooling fans. I don't think you took the light engine apart to clean out all of the glass so the main cooling fan is probably not running and causing the warning. There is no sensor for the mirror. Did you remove the chassis to clean the glass? You cna remove it again and try powering it up out of the cabinet. There are four fans that need to be running. If the light engine is filled with glass the fan at the bottom of the air exhaust will not turn.
I am fairly certain that since the TV was discarded there is more wrong with it than a broken mirror.
Jan 22, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Brightness (hellllpppp!)
To answer your question nothing is going to drop inside the set,I also need to tell you that a cleaning of the inside is not going to correct the problem,you should get at least the opinion of a servicer to determine if the set is repairable or not,an experianced techician should have a very good idea as soon as he sees the picture,if he sees the need to remove the back cover that will be a good time for you to see if it needs cleaning,Be safe and get an estimate.
Sep 29, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
