Question about Garden
I have a DeWalt compressor and it does not automatically shut off anymore. any ideas
  • 2,510 Answers
Does it reach the normal cut-off pressure (110-120 psi). If it does then the relief valve must be cutting in to protect the receiver and you need to replace the cut-out switch. If the pressure does not reach the cut-out pressure then:- a. the relief valve is leaking . b. there is a leak in the system somewhere, use soapy water and paint brush to look for leaks. c. the compressor has lost efficiency and needs at least new rings.
Posted on Apr 08, 2011
Dewalt d55155 compressor runs to 60 lbs then acts like not enough power and shuts down
Looks like it's an oiled style compressor. Is it getting pretty hot by the time it hits 60psi? Might be low on oil, or the oil has been contaminated with water from condensation. If that's the case then what is happening is the compressor is causing too much resistance for the motor to turn it because of the excess friction. This is could be what is causing it to shut down prematurely.
Nov 23, 2012 | Dewalt D55155 Emglo Air Compressor
I'm using my dewalt for bead blasting projects, Lately moisture is coming from the pistol
It's on the bottom, right hand side of the tank if you are facing the tank side. You can download the owners manual from this link. It is at the upper right side of the page in the section marked downloads.
DeWalt D55155 parts and owners manuals
Aug 21, 2012 | Dewalt D55155 Emglo Air Compressor
I have a Dewalt D55141 Air Compressor that will work normally through one or two cycles, and then when it try's to power again it will just hum and quite repeatedly until I shut it off. It also bleeds...
I believe that you have a very simple problem related to the in-tank check valve. Follow the discharge hose from the compressor to the tank. It should connect to a brass or chrome valve. This valve has a one way check valve that allows air into tank and not return to compressor (if air leaks back, compressor will be under load (motor will not overcome) and air will leak from the pressure switch unloader valve). With air in the tank, remove the hose at the check valve and spray soapy water to verify leak, replace part or clean as needed. Good luck
Sep 30, 2011 | Dewalt Air Tools & Compressors
I have a D55168 Dewalt compressor. Since I've had it, it has never shut off automatically and I've always shut it off manually at 200 psi. If I leave it alone, will it automatically shut itself...
Your concern is very well placed, at pressures that high a lot of damage can be caused by a failure. According to the manual for this model air compressor the approximate cut-in pressure is 160 psi and the approximate cut-out pressure is 200 psi. Meaning it should pump up to 'about' 200 psi and shut off and not come on again until it gets down to 'about' 160 psi. They say approximate and I say about because it's not an exact science setting the pressure switch. Spring rates are not always exact, pressure guages are not that precise, etc. When turned on, it should shut off at 200 psi +/- 10 lbs. If it goes more than 10 lbs over that (220psi), I'd recommend you get the pressure switch and or guages checked or replaced.
Jun 16, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
HOW MANY CFM DOES THIS COMPRESSER DELIVER AT 100 PSI
If this is the compressor the amount is 16.2 at 100PSI. PLease see attached link:
http://www.toolfetch.com/p-d55275.shtml
I hope this may have helped,
Tom
Oct 16, 2009 | Dewalt D55275 8 Hp Gas - Powered 17 -...
How to fix compressor air gas 55 hp dewalt it
that is probably the top end for this machine. If not sure, visit the web site of the manufacturer.
Oct 10, 2009 | Dewalt 5.5HP 8GAL Gas Wheeled Portable...
Cooling Fan is not working automatically
thass as good idea, but instead justreplacethe existing fan ( which is your problem)the fan is no good, so rewiring will not help any. replace the part!
Mar 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Compressor will not shut off
The switch is bad, replace it, this should solve the problem.
Nov 17, 2008 | Dewalt d55151 factory reconditioned emglo...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
