Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
New refrigerator makes a grunting or gurgling noise
We have a frigidaire refrigerator-top freezer--bought two weeks ago--last few days when running it makes what I say is a grunting sound every 30 seconds or so (My husband says a gurgling noise) its around the freezer. at night we can hear it because the bedroom is just off the kitchen. Is this normal? it goes grunt- grunt, grunt. very anoying
  • 1 more comment
  • Merksi Dec 14, 2008
    I also have a new Frigidaire refrigerator - mine makes weird gurgling/clicking sounds, but only once in a while.
  • Anonymous Dec 29, 2008
    Mine makes these gugling and clicking sounds about every other hour, and they appear to be getting louder. Does anyone respond to this board?
  • Charles Tuck
    Charles Tuck May 11, 2010
    Does this refrigerator have an icemaker?
2 Suggested Answers
  • 4793 Answers
SOURCE: samsung refrigerator
its got indigestion(gas bubbles)this should settle down after about 2/3 weeks..you could try turning it to its coldest then back off to -18
Posted on Jul 09, 2010
  • 351 Answers
SOURCE: I bought a new frigidaire
hmmm, could be in defrost cycle when that happens, when the defrost element warms up and the frost/ice drips it then makes sounds about how oftern do you hear the noise?
Posted on Dec 18, 2010
I just got the side by side Frigidaire professional and every few hours there is a loud noise that comes out of it that last like 3 seconds
Thanks for your post, friend!
I see that your Frigidaire side by side refrigerator is making a loud noise every few hours. There are a lot of normal operating noises within a refrigerator. It is possible that your evaporator may create a boiling or gurgling noise. Or you could be hearing ice being released into your ice bin. If you have your manual they should list some normal operating noises within your refrigerator. I hope this information has been helpful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
I bought a new frigidaire fridge with the freezer on top. It's made a weird grunting, gurgling, groaning sound on and off from day one. Should have called Leon's where I bought it to complain but never...
Dec 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gurgling noise for about 5 seconds when closing freezer door or refrigerator door
See tis for sources of noise:
http://www.applianceaid.com/images/fridgenoises.JPG
Jan 31, 2010 | Frigidaire FRT18S6AW Top Freezer...
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
My new frigidaire refrigerator model# FRT18S6AWX is unusually noisey . It makes gurgleing sound and it last for 10 seconds . it does this throughout the day once every half hour. We reported it and were...
hi, this is not normal at all. this is a manufacturing flaw the resides in the compressor build. there is way to much pressure being produced threw the lines. the compressor regulator seems to be flawed in its design. i would recommend purchasing a aftermarket compressor Assembly for this unit. the noise itself is a dead give away for flawed compression in the core Assembly.
Mar 11, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
626 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
