I need to install a one for all URC 3940 universal remote to my telly but I haven't got the codes or instruction manual please help
4 Suggested Answers
SOURCE: hi i have lost instruction
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Posted on Sep 11, 2010
BElectric
  • 1140 Answers
SOURCE: i have a currys essentia
I'd like to be able to give a more positive answer but I don't think this combination of remote and TV will work together. One-for-All do not list codes for Curry's brand devices. These are simply 'badged' TVs from an often unknown manufacturer.
As there are no codes listed for your brand, identifying a code which will work is limited to trying to identify the original manufacturer of the TV and hoping that your TV shares common components with a TV that your remote does have codes for. There are too many codes in the remote to try to guess a code or to try them all using the manual code entry method.
Your best option is to try the Code Search:
1. Switch the TV on.
2. Press the "DVD" button on your One-for-All remote
3. Press and hold the "MAGIC" button on the remote until the red LED under the POWER key flashes once, then twice.
4. Enter 9 9 1 using the number keys on the One-for-All remote
The LED will blink twice again, indicating that the code search is active.
5. Press the "POWER" button on the One-for-All remote
6. Point the remote at your TV and press the "CH+" button slowly and repeatedly until your TV switches off.
7. As soon as (or if) your TV switches off, press the "MAGIC" button again to store the code.
8. Test the remote with the TV for the common functions, i.e. POWER, VOLUME and CHANNELS.
9. If the TV does not respond (or does not respond as you would expect), go back to step 1 and continue the code search . This does not restart the code search from the beginning, it simply picks up from the code that is currently set and continues through the code list.
Please note: There are hundreds of codes stored in the remote so it can sometimes take half an hour or more to search through them all.
Your TV is a DVD combi so this means the correct code should be stored in the code list for DVD players. However, as it is impossible to discover the true identity of your TV, it is also possible that there may be a code that will work with your TV in either the TV or VCR code list. You can try repeating the code search as above, but in step 2, press either the "TV" or "VCR" button instead to run through the codes for these device types.
It is also possible to control some TV/DVD combis by using two codes. Run through the code search in "TV" mode first. If you can find one that will operate the TV functions, store it, then run the code search again in "DVD" mode. You may then find a second code that will operate the common DVD functions, e.g. PLAY, STOP, PAUSE, etc. If this method works, you simply need to remember to press the "TV" or "DVD" button on the remote first - depending on which function you are trying to control.
There is a "pot-luck" element to getting any universal remote to work with any device. There are hundreds (maybe even thousands) of universal remotes and thousands of brand/model combinations of TV. This means there is an almost incalculable number of combinations of TV and universal remote and expecting there to be a code for every device is unrealistic. Unfortunately, this element of luck also increases for devices from a lesser known brand and even more so when the TV is newer than the remote.
Please try the code searches as detailed above. This can require a lot of patience. If you still can't get any response from the TV, then it's unlikely that your particular combination is one of those that will work. You would also be taking the same chance with any other universal remote, even if you bought a new one.
If you can't get any results from the code search, please post back for further assistance.
Regards,
BElectric
Posted on Dec 30, 2010
jyackle5
  • 8197 Answers
SOURCE: hi i bought a new
You can get the manual for your remote on the link below.
http://www.oneforall.com/uploads/support/b444ffdd1b4a99e74e2be53901dae56e.pdf
Posted on May 12, 2011
Manual on URC-3940
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Aug 08, 2014 | GE Tv Dvd Vcr Audio Universal Remote...
No instructions for universal remote
I can help you with your URC-3021 Universal Remote Control issues.
You can download the One For All URC-3021 Manual for free here.
I hope that helps.
_______________________________________________
One For All URC-3021 Code List
One For All URC-3021 Code Entry
One For All URC-3021 Code Search
One For All URC-3021 Reassign Key
May 15, 2010 | One For All URC-3021 Remote Control
I need to program one for all urc3220 remote for my toshiba television
I can help you with your URC-3220 Universal Remote Control issues.
The codes for Toshiba TV's are: 0154, 0156, 0060, & 1256.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
Feb 07, 2010 | One For All URC4110 Remote Control
I need the codes and manual for a universal remote urc-3021 and the codes for a sylvania tv
The codes for Sylvania TV's are: 0054, 0030, & 0171.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Jan 03, 2010 | One For All URC-3021 Remote Control
I need the code for urc3220 remote sanyo tv
The codes for Sanyo TV's are: 0154 & 0159.
I hope that helps.
Dec 30, 2009 | GE JASRM24912 Remote Control
NEED MANUAL INSTRUCTIONS
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sony TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Oct 04, 2009 | One For All URC4110 Remote Control
Need code for urc3220 and instructions
The URC-3220 codes for Orion TV's are: 0236, 0463, & 0179.
I hope that helps.
Jul 08, 2009 | One For All URC-3021 Remote Control
Televison & Video Logo
1,381 people viewed this question
Top Televison & Video Experts
Electro Med Services...
