Question about Sony Audio Players & Recorders
We understand that your problem is: Sony STR-D365. When powering up, the display doesn't show anything. The only lights that come on are on the volume control, mutting and bass boost. Please be advised that no fuse is burned and there is no clicking sound heard. The red standby light only flashes for less than a second then goes off. Basicly the amp is dead..
  • 643 Answers
Usually means your powersupply is bad. Try going to Sony Esupport.com for a flat rate repair.
Posted on Apr 09, 2011
Testimonial: "I'm not a service tech, so I'm here to listen and perhaps learn. Thank you for addressing my questions"
  • Tony VRACHNAS Apr 09, 2011
    Thank you for your reply
    Sony products in my opinion are good however Sony Service in Athens Still has an Amp I sent them for repair from two years ago, so I aint going down that road again. I was trying to understand the fault myself, so maybe I could fo a DIY. I have tested the standby transformer and it works ok, But the relay on the stand-by board won't click to turn on the unit. The stand-by board has 220v, I traced the 220v going to the power switch and back to the standby board board. The question I have is, from where does the relay on the stand-by board gets power from? If it's the power supply as you say, can you maybe give me the part number.
    Cheers
I have a Sony reciever (STR-D365) and Time Warner remote (8780L). I found the codes for that combo but none of them are controlling the volume function. Power on/off and mute are working but nothing...
083,091,077. Check these codes. If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given.
May 18, 2013 | Televison & Video
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
I NEED TO RESET Sony STR D365 Receiver BACK TO FACTORY SETTINGS, CAN THIS BE DONE??
I believe what you want to do is as follows. Turn off the power supply. Hold the buttons 6, 7, 8. And turn on the power. The display should activate all options, then turn on and off a few times and finally display End. Then the memory should be reset back to Factory.
Apr 11, 2011 | Sony Audio Players & Recorders
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony str-de845 powers on, relay clicks sound works for a few minutes then relay clicks again and sound stops. display stays on.
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Jan 22, 2010 | Sony STR-DE845 Receiver
Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
Sony STR-DE310
Our Sony STR-DE310 displays the message "Protected" and will not operate. We have not used it for awhile, but it worked finte the last time.
Jan 27, 2008 | Sony STR-DE310
No display
it is a bad fuse or the i.c. chip is bad
Jan 02, 2008 | Sony STR-GA8ES Receiver
693 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
