Question about Bionaire BAP825-U Air Purifier
I have been given a Bionaire BAP825RC Unit and don't really know what it is. It is electric, but do I have to put anything inside of the tower unit or does it just work from the electricity, and what does it do, please. Many thanks. Anita Kilford
How do you reset light indicators after replacing filters
there should be a pin hole at the top of the unit by the lights and power button. you will need like a sewing needle to put in there. hold for about 5 seconds and the unit will reset. if that doesn't work. you need to turn off the unit unplug it for about 10 seconds and plug back in. if that doesn't work please let me know.
Oct 31, 2009 | Bionaire BAP825-U Air Purifier
I have recently purchased a bionaire bap 1550 air purifier. Is it normal for the recirculated air only to come out of the left hand side of the front grill
no that isn't normal. it should be coming out of both sides cause the air intake is in the back of the unit where the filters are. try to reset the unit but the pin hole at the top or unplugging the unit for about 10 seconds.... if that doesn't work i would call the manufacturer and to see what other ways or if the unit can be replaced.
Oct 29, 2009 | Bionaire BAP1500-U Air Purifier
HOw do i get the red light to go off after changing the filters?
there should be a tiny in hole at the top of the unit. when the unit is on put a pin inside that hole and hold it for about 5 seconds. then release the unit's lights will all come back on and then it should be reset as if you just turned the unit on. if that doesn't work please let me know and i will see what else i can do for you.
Jul 17, 2009 | Bionaire BAP825-U Air Purifier
Black Filters for Bionaire BAP1500
the only other places that you could check would be like a hardware store. kmart, wal-mart. if you have those in your area. ace hardware. places that would normally carry that unit. the big ones mainly are lowes and menards.
Mar 29, 2009 | Bionaire BAP1500-U Air Purifier
Bionaire BAP1700
on the bap1700 it is very quiet. i used to have one myself. sometimes you will feel the air and sometimes you won't all depends. if the fan is running than the unit is working properly. now if your hearing any noises or anything like that then there's a problem. but no to answer your question you didn't buy a lemon. if you have any other questions please let us know.
Mar 18, 2009 | Bionaire BAP1500-U Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Red filter light still on-
ok i'm not finding that model anywhere in my system. but one way you can try is look in your manual under troubleshooting. if you have gone through all of the troubleshooting. the best thing that i can suggest is call the manufacturer. if your still under warranty they should be able to replace the unit foryou.
Nov 04, 2008 | Bionaire BAP1175-U Air Purifier
Reset Filter Indicators on BAP 725
there should be a small pin hole somewhere on the top of the unit. Stick a pin in there hold for about 3 seconds and it should reset.
Sep 01, 2008 | Bionaire HEPA Air Purifier Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Bionaire filter replacement- reset indicator
It worked - the solution to press sleep and the power button simultaeneously worked! Air cleaner then reset to 99%. Thank you Harbourman!
Oct 31, 2007 | Bionaire BAP1175-U Air Purifier
Bionaire BAP825-U Air Purifier Logo
180 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
