Question about Dryers
Hi the belt has snapped and would like help on how to change it thanks
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Also check out the following website for belt help.
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
This is a FREE answer, Please rate me
Posted on Apr 08, 2011
What causes engine belt to break?
Hi there is a few resons for this to point out a couple,not being changed at the right intervals,can be water pump wich some cars have the timing belt drive the water pump,so when the water pump bearing sesses up the belt will snap.
hope this might of been some help.
Mar 08, 2014 | Mercedes-Benz E-Class Cars & Trucks
Dyson DC07 belt change has resulted in very noisy vacuum!
Hi I agree with the first 2 solutions above but not the 3rd one.
If you have suction coming through the hose when the machine is in upright position then the u bend has nothing to do with this problem.
Right so ... The belt snapped.
The answer to you question is "why did the belt snap" its true that it could just be old age but its more likely to have been caused by a foreign object being sooked up.
How the belt/brushbar/motor interact
Your belt simply connects the motor to the brushbar know as Direct Drive. If an object get inside the space between the motor and the brushbar or if it can jam the brushbar then this will cause the rubber to burn. The motor will keep spinning and the belt wont be able to so will snap.
So its easy to see that the belt has snapped and people just think "'oh the belt has snapped"
You might wonder where im coming from here.
Anyway because the brushbar got jammed it may also have been buckled slighty either as a result of the foreign object causing it to stop suddenly from spinning at high speed or/and the result of the heat build up.
The rattling noise you now find your Dyson making is more than likely because your brushbar is buckled and when it spins the bristles are hitting the housing unit.
Your belt will snap again unless you replace the brushbar
Apr 10, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
A technician stated my alternator belt has a slight crack...how long can I continue to drive with the crack
Nobody can tell when that alternator belt will snap, but the crack means its time to change it.
For precautionary and preventive maintenance purposes, the mechanic just advises you to change that belt before it will snap in the middle of nowhere.
If I were you I will follow the advise!
Hope that clears all the doubts!
Thank you for using Fixya!
Dec 08, 2010 | 2000 Mitsubishi Montero Sport
Hi i have just purchased a 2004 focus c-max 1.6 tdci diesel and i am unsure of the cambelt change interval..? Many thanks for your help..
i would change the belt/tensioner at 80k.regardless of makers reccomendation,(they dont pay the bill when it snaps)
Nov 12, 2010 | Ford Focus Cars & Trucks
Change moter alt belt keeps breaking
Hi the altenator belt? if it keeps snapping then your altenator is rather starting to seize up or its not fitted correctly, normally if its squeking its to loose.
Spin the altenator by hand and see what it sounds like, if its hard to turn or noisey that the fault.
hope this helps.
Jan 16, 2010 | 2000 Kia Sephia
Snapped cambelt
you mean the timing belt..well you can bent your valves if your not lucky mostly engine running with interferance ingine but yea if your timing belt snap it can damage your valve timing belt should be change at every 60k miles or suffer later..
Mar 31, 2009 | 2000 Daewoo Nubira
I need to replace the fan belt. Which pulleys does it go around?
My brother in law and I changed it without taking anything apart except the fan cover, what you'll need to do is gently use a crobar to release the tensioner pully directly below the alternator, and jam it a bit, then slowly release the old belt, if it's as worn as mine was you'll be fine. Then simply run the new belt starting from the bottom up. There's a great diagram on the weblink below.
http://www.roverparts.com/TechTips/serpentine_belt_routing_D2.cfm
Dec 27, 2008 | 1996 Land Rover Discovery
Timing belt
Hi, I have a 1997, Daewoo celio 1,5 I and the cam belt snapped. I dont think that the pistons hit the valves but I cant be sure, I have a new belt and woud like some info on how to go about changing the belt and setting the timing on this car. I am not a novice mechanic but need some advise. Thanks Brent
Jul 24, 2008 | 1999 Daewoo Lanos
Broken Cylinder head valves
sounds like your timing belt may have slipped or snapped a ceased timing belt adjuster could cause this check your timing belt and adjuster and all belt adjustment pulleys before you fix the valves otherwise its bound to happen againalso make sure your engine oil is full
Jun 11, 2008 | 2000 Volkswagen Jetta TDI
Changing belt
ok hi pretty lady
ok back to dryer, belt go's around drum and tension pully at bottom then to the electric motor
Jan 20, 2008 | Dryers
Dryers Logo
Top Dryers Experts
