Question about Cameras
Camera was briefly submerged in salt water over two weeks ago. Replaced battery with new one. Nothing happening.
  • Cameras Master
  • 6,771 Answers
If the camera took on salt water it is already to late, the salt corrodes the ic pins and eventually moves into the casing and destroys any delicate parts, the only option is replace the camera.
Posted on Apr 08, 2011
My Canon 60d fell in salt water, briefly but enough to submerge. It has dried out and will now turn on but keeps showing error 70. Is there any chance this can be fixed? Could it dry out more and work?
I'm afraid the salt already started to corrode the inside of the camera. Are you sure you cleaned the connection points of the battery and memory card? I mean both the ones on the battery and memory card and the contacts in the camera. Do not use any sharp objects to clean the contacts, because you will damage them bend repair. If the error stays, you have to contact a Canon support centre close to you.
Oct 25, 2013 | Sanford Canon EOS Rebel K2 35mm SLR...
Salt water
Yes, because the water resistance is not effected by the salt content of the water.
Salt water is very slightly corrosive in it's natural state, but it can become very corrosive as it dries and the salts attract and hold on to moisture that can keep it's corrosive properties active long after you take it out of the salt water.
If you expose your camera to salt water rinse it off very well with fresh water once you're finished.
If you can see the seals in places like the battery compartment, you might also occasionally give those seals a coating of silicone grease.
If the worst happens and you notice moisture inside the camera, remove the batteries IMMEDIATELY and try to remove the moisture any way you can, even with cotton swabs if necessary.
Pure water is not conductive but most tap water and certainly salt water is, and if salt water bridges electrically charged parts of your camera when the batteries are in the camera, it will remove metal from one side and deposit it on the other side, (electrolsis), and that will permanently ruin you camera.
Oct 25, 2013 | FUJIFILM FinePix XP20 / XP22 Digital...
Cell phone salt-water damage
Put it in a bowl of rice and stick it in the hotpress!
Doubt it will work since it was submerged for so long but worth the try!
Owen.
Jan 11, 2013 | Nokia 1661 Cell Phone
What can I do to turn on my digital camera after it was submerged in water?
First of all you should get (or have gotten) the battery out as soon as possible. You could try shaking excess water out of it. You should then put it in rice to draw all the moisture out of the camera. This may take a couple of days, maybe exchange with more dry rice after first day. When you are relatively sure all moisture is gone try reinstalling the battery. I will guess that you will only have a 20% chance of it ever working again.
Dec 21, 2011 | Canon Cameras
It was dropped in ocean more than a week ago . Now not turning on. What can be done to fix it?
Even if you dried it properly (burying it in a bowl of dry rice for a week before even trying to turn it on), salt water is very corrosive and continues to do damage for weeks and months. It also dries to a salty film on the lens elements. Dropping a camera into salt water is usually a death sentence for a camera. Even if you could find someone willing to repair it, the cost would be astronomical since everything except the case would have to be replaced.
Dec 18, 2010 | Canon PowerShot A560 Digital Camera
Is there a fix to salt water immersion of camera?
Water, any kind of water is a conductor of electricity. If you truly dried out the camera and it will not power up it probably shorted out. The one thing that might clean any minerals or salts out of the camera that is readily available is rubbing alcohol. With the battery removed, submerge the camera in rubbing alcohol and swish it around, then drain it and let it dry. Do not use anything like a hair drier to do it because alcohol is flammable. After it is dry, install a charged battery and see if there is any sign that it powers up. This is a real long shot and I would use this as a last resort. Getting the camera fixed would probably cost as much as the camera. One other idea, if you have a Homeowner's Insurance policy, is to see if they would cover it.
Mar 22, 2010 | Cameras
DROPPED CANON POWERSHOT SX10 IS IN SALT WATER (NOT SUBMERGED). WILL NOT WORK. ALLOWED TO DRY OUT SEVERAL HOURS, INSERTED SD CARD AND BATTERIES. DOES NOT TURN ON.
First of all, it would take days, not hours to dry out. Turning it on too soon can fry the circuits. But worse than that, salt water is extremely bad for a camera. Most places won't even repair it.
Sep 25, 2009 | Cameras
Canon Powershot 870IS accidentally submerged in water.
when the camera falls in the water, only the power supply would have got bad, just take it to the manufacture, he will replace the power unit, it will work as good as the new one,, thank you,, plz rate me
Jun 30, 2009 | Canon PowerShot SD870 IS Digital Camera
Play & Menu buttons/display not working properly after water got in
I took mine surfing, and it leaked salt water (just a couple of drops) into the battery compartment. I rinsed the whole camera with fresh water, and the camera came back to life -- but had similar display issues.
I had the camera serviced at Best Buy, where I had purchased a 4yr maintenance contract. In addition to fixing the electronics, they replaced the door on the battery compartment with one that has a metal hinge instead of the original plastic.If you don't have a warranty, then getting a used replacement is by far the cheapest route.
My advice: buy another one on eBay or Craigs. I just got a second one two weeks ago for $70.00 and it is working perfectly. This is an awesome camera, and worth the hassle to repair or replace.
Nov 06, 2008 | Olympus Stylus 720 SW Digital Camera
Dropped camera in pool
Open camera and place in a bag of rice for a couple of days to absorb moisture.It's worked before on cell phones.
Jun 30, 2006 | Canon PowerShot A70 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
