Question about Lincoln Welding Tools
Lincoln power mig 300.when i weld, the wire globs in puddles on my work piece. i have tried adjusting speed and voltage. i need a direction to follow to fix the problem.
  • Michael Jones
    Michael Jones Apr 09, 2011
    i found the problem. i have a push pull gun and the nozzle assy. was not seated all the way in. this caused poor gas flow and incorrect voltage sensing. it turns out the welder automaticaly senses the voltage differences and adjusts accordingly. i cleaned and reseated the nozzzle assy. and she fired right up.thank you for your help.
  • 407 Answers
Hi:
Sound like you have the wrong polarity for the wire you are using. Without knowing what kind of wire you are using, check the following:
A) If using inner shield wire (gasless wire) your ground clamp must be connected to the positive (+) side and your ground cable to negative.
B) If using metal core wire (need gas) ground clamp must be on negative side.
Polarity change it's done on the upper side of the drive rolls.
Good luck.
Posted on Apr 09, 2011
I have a Rossi 100 amp mig Gasless, has no grunt to weld with.
turn up the voltage regulator
the more volts the more amps available
check for proper;y connected ground
make sure that you have the ground wire connected correctly to the machine
ground and live are reversed for gas less operation ( in the user manual)
Nov 25, 2017 | AMP Welding Tools
How do I weld upright posts on square tube base so that same size square tube stays 90 degree when tacked.
Anytime you weld something or even tack anything together, your joints are going to move some. You could position your pieces to compensate for this or you could clamp them down. But no matter what, when that weld puddle solidifies, it will pull and the stresses exerted on your work piece can be pretty high. If you can't clamp it in place to minimize movement, try tacking one spot on one side, then--using a your favorite hammer--influence your piece back straight and tack the other side. Once you have solid tacks that are going to hold your piece as square as you can make them, then weld it out, alternating sides and direction of travel. Of course minimize heat input as much as possible. Travel speed has more to do with heat input than amperage or voltage in many cases. Its a little hard to give you specific recommendations on your project without knowing more about your set up there. So tack, straighten, tack, straighten, tack straighten and so one...then weld it out.
Apr 25, 2016 | Welding Tools
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Wire feed have erratic speed when welding.
adjust your speed either up or down to match the amps required to weld
Jun 08, 2015 | Lincoln Electric Handy MIG K21851 Welder
I have a lincoln sp-100 welder and despite having a good ground the weld quality is just not there. Any help is appreciated
Let's troubleshoot this one:
1) Make sure you have the right polarity for the wire you are using: Innershield wire (no gas) ground clamp must be on the + side. Solid Wire (gas use) ground clamp to negative side.
2) If gas is used: Mild steel welding requires Argon/CO2 mix 75/25 or 90/10. Using pure CO2 you will create a lot of sparks and a lot of fumes. Stainless Steel welding requires a Trimix gas of Argon/Helium and CO2. Aluminum Welding requires pure argon. Any use of gas requires a steady gas flow of no more than 25 SCFH. If you use more than that or less you will find porosity on the welding.
3) Your work piece must be cleaned before welding (no grease, dirt or paint).
4) Check your machine welding chart for wire speed and voltage.
If you still experience problems with welding quality, check you input power voltage, make sure it doesn't fluctuate.
Goooooood Luck.
Aug 30, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
Wire is broken off inside wire feed tube and wont pull through tube either
Hi:
You need to replace the gun's liner. To avoid this problem you must decrease the voltage or increase your wire speed.
A new liner will cost you around 20 buck at your nearest Praxair welding store.
If this was useful to you please vote. Thanks
Apr 15, 2011 | Lincoln Electric Handy MIG K21851 Welder
Some proplems face in welding aluminum
Are you asking about what the problems would be? First for mig welder, you can't push small aluminum wire through a very long cable. You need a teflon liner for it to work at all. A spool gun works better. Be sure to use correct gas for aluminum. Usually 100%argon, but some people use Argon/helium or helium. Use direct current reverse polarity (electrode positive) from constant voltage (CV) power supplies. If shallow penetration is required (i.e. for weld surfacing and cladding) straight polarity (electrode negative) can be used
Sep 27, 2010 | Lincoln Electric Welding Tools
How do you ignite a Lincoln Electric Welder???
You don't need an striker with a MIG welder just hook the ground cable to the base metal point the nozzle where you want to weld and pull the trigger and it will weld. Household current will run a MIG welder Take a look at the plug on the welder if it will pug into a 110v outlet you are all set, but most likely you will need a 220v outlet and maybe as much as an electric dryer type outlet.
It takes a lot of practice to be a decent welder you also need to know what voltage and wire speed settings to use for a given thickness and type of material.
You don't mention shielding gas, if you are using a flux core wire you don't need it, but if you are using regular wire you do.
If I may make a suggestion, If you really want to learn how to weld, find a community college near you and take an introductory welding class. You will get a wealth of information and practice on different welding processes. The instructor will work with you and get you welding much better and faster than you will on your own. Most importantly you will get a lot of safety information.
This is a good introductory book:
http://www.amazon.com/Welders-Handbook-RevisedHP1513-Cutting-Oxyacetylene/dp/1557885133/ref=ntt_at_ep_dpt_1
Mar 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
I have a Lincoln 140 mig welder. It welds and cuts
Usually this is caused by a bad liner in the mig gun hose, or worn out guide rolls in the drive unit, or if this is not the case the speed of the wire might be set to high as this would force the wire into the weld causing the motor to heat up from resistance and shut it down on safty. Hope This Helps Don
Dec 02, 2009 | Lincoln Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Welding Tools Logo
163 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
