Question about Sierra Online, Inc. Lords Of Magic for Windows
Every time I try to save my Lords of Magic game, it says "error saving game." How can I fix this?
Lords of Magic wont run
Many older games have problems running on newer systems, and while windows' compatibility modes can sometimes help, most of these games require specific work-around to get them to work on a modern system with a modern OS. You will need to look for consumer support (IE: Forums) for the specific title you are trying to play as it relates to your hardware and OS. Sorry I could not be of more help.
Nov 16, 2012 | Sierra Lords of Magic
Hello, I bought the game "Medieval Lords". Then, I set it in my computer successfully. But when I want to open the game, I have this message : i get an error message that reads mcINI.ccp(1599) abort o
Check you have the correct Operating system and that you have the original game. If you are running the game on a machine with Vista or Win 7 you will have problems. Check this link to see if you have the spec required.
Mar 14, 2012 | Avanquest Medieval Lords: Build, Defend,...
I am trying to open "Backyard Soccer 2004." I tried to open the website in the troubleshooting read-me. The link was http://www.ina-support.com. That took me to http://www.atari.com/. Anyway when...
If you have the game disk, put it into your CD tray. Use the Disk to re-install the game to fix any errors. Most games that have this feature will ask if you would like to save your game files, and will prevent you from losing any of your saved games or settings. The game will prompt you to install the game, or play it. Click the install option and it will ask if you want to repair it, or clean install. Click repair if the option is there, if not, then run a clean install and that should fix your issue
Jun 26, 2011 | Infogrames Backyard Soccer 2004 for...
I cant save the game... every time i try doing that i get the same error: "Save failed! there was an error while saving the current game. Please check you're savegame directory and try again."
There should be a "GTA San Andreas User Files" folder in your "my documents". Make sure it's there. If it's not there, create it, if it's there, try manually deleting all the save files and creating new ones.
Mar 05, 2011 | Rockstar Games Grand Theft Auto: San...
I have Windows 7 and my H4 autosave keeps failing. What do I need to do?
try run the game in compability mode and/or admin mode and see if that fixes, most of the times its just 'cuz your game doesnt have the privileges to save
Dec 23, 2010 | 3DO Heroes of Might and Magic 4 for...
Medieval lords not running
Hello wilsonpaul74
As far as I know, there isn't a patch for Windows 7. Have you tried running it in compatibility mode? There are two ways to do this:
OPTION 1 - TROUBLESHOOT COMPATIBILITY
1. Right click on the programs shortcut, .EXE file, or installation program, and click on Troubleshoot compatibility. N.B. You will not have the Troubleshoot compatibility option available for pinned items in the Start Menu or on the Task Bar.
2. The wizard will now give you a list of options to choose from. Try each individual option, following the on-screen instructions.
If this doesn't work, you can try the following option.
OPTION 2 - THROUGH THE PROPERTIES PAGE
1. Right click on the programs shortcut, .EXE file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. Check the Run this program in compatibility mode for box.
5. Click on the drop-down menu arrow, and select which version of Windows the game was made for. N.B. Always pick the latest Windows version the game was made for a better chance of it running properly.
I hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | Monte Cristo Medieval Lords for Windows
Age of empires save game problem
I had the same problem several times with AoE Rise of Rome , when I try to load a saved game it crashes to windows with an error .. first I tried to solve it by saving the game more times in a row , like three or four times , but once all four of my saves were corrupted or whatever so I tried to save the game while not having any building or unit selected . So far it works fine , but some saves where I had sth selected worked also . DON'T KNOW if this is a TRUSTY solution , but as I said I had no errors so far.
Nov 13, 2009 | Microsoft Age of Empires: The Rise of Rome...
Erorrs every time i try to save MGS3
ARe you using the original SONY MAGIC GATE memory card?If not than this is the problem.
Jul 24, 2009 | Video Game Consoles & Games
Sierra Online, Inc. Lords Of Magic for Windows Logo
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
steve morris
steve morris
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
