Question about Sony SLV-SE830 VHS VCR
Hi there, Having some trouble with the Sony SLV-SE830 VHS VCR. It should just work once the power is switched on and the SCART lead is connected to the back of the TV and the AV channel is set to the SCART port the VCR is connected to, right? Does it require any tuning in or anything? The VCR is definitely working (I've put a tape in it and all of the information on the screen of the VCR is coming up like running times, etc).
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
If you tv has more than one SCART connector.. ensure you have the cable plugged into the proper one.
Not sure what the problem is.. if you have a modern bidirecitonal SCART cable properly connected.. you should be able to view and hear the tape as it plays.. assuming the machine is in good condition.
Of course if you want to record a program other than the one you are watching you will ned to supply an independent broadcast signal to the VCR.. and yes you may have to program the tuner on the VCR if you want to record.
However if you simply wish to view tapes.. you shoud be set to use the machine as connected.
Best of Luck!
Posted on Apr 08, 2011
Need new sony vcr remote
Try searching Curry's Partmaster website, if you are in the UK.
Mar 30, 2013 | Sony SLV-N750 VHS/S-VHS playback VCR
I have a sony SLV-SE730 will not show any picture on my Brava Tv set does it matter what scart lead i use
First of all scart leads are notorious for bad connections. The pins can get pushed flat and not make contact. Look carefully at the connections at both ends of video and TV. Sometimes moving the socket while in the back of the TV/video will spring it into life. You can get higher quality gold platted leads if your old one plays up like this. Most TV's will have a dedicated socket for the VCR, the other being for satellite etc. In most cases it will say just below the socket. Otherwise try AV1 first.
Feb 14, 2013 | Sony SLV-SE730 VHS VCR
I am trying to connect my vcr to my tv and am having many problems. does the vcr need cable? or can it conect solely to a tv? thanks.
If the TV has a scart socket then you should be able to connect it via a scart lead to TV from the VCR. Apart from feeding an aerial lead to the VCR first then out from it to the TV aerial socket it should work fine.
Aug 09, 2011 | RCA VR349 VHS VCR
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
Hi! I'm looking for a user manual for my newly acquired Sony SLV-2000 VCR. I've Googled and gotten nowhere. Lots of dead-ends. HELP!
Problem solved. I went online and found a pdf file for the Sony SLV-R1000 manual. This manual works just as well for the Sony SLV-2000. I'm a happy camper...
Jan 08, 2009 | Sony SVO-2000 S-VHS VCR
Intermitent colour and black & white picture when recording through Line 3
your vcr tunner is faulty take it to a tech and have him change the tunner.or probably you are connecting the wires wrong.
Feb 17, 2007 | Sony SLV-SE840 VHS VCR
Sony VCR date only goes up 2006
I have 2 SLV-696HF units that won't work after 2007. I have had people tell me that I'll have to "find" a previous calendar that will work, since there are only 14 different calendars in our Gregorian system, 7 for non-leap years & 7 for leap years. The problem we have with this, is that the internal VCR calendar won't roll BACK far enough. I wonder if SONY has a way of flashing these units to fix this problem?
Jan 12, 2007 | Sony SLV-M91HF VHS VCR
Video signal into VCR
you have to select to switch from comopsit to s-vhs for the video input in your sony slv -n55 to get the video reached to it regards please don't forget to rate ,thx
Oct 15, 2006 | Sony SLV-N55 VHS VCR
Sony SLV-SE830 VHS VCR Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
