Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
3347 Router Key
I need to get the key so I can install my wireless adapter software. How can I get that information quickly?
  • 35 Answers
If you mean to say, your WEP key or password(network key) to allow your computer to go online wirelessly, you need to access the Netopia's setup page via a browser. From there, you can go or click the wireless section/tab which will give your settings for your network like security key or network name.
Posted on Aug 06, 2008
6ya staff
SOURCE:
I have connected my Belkin wireless adapter to my laptop computer and where can I get the Network key?
The network key will be dependent on the settings of the router providing you with the wireless signal, not the adapter receiving it.
Mar 01, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
AT&T tells me that I need Netopia3-D Reach to connect to my 3347 NWG and will work with Ubuntu...no problems. True?
Not true. Any wireless b/g adapter will work -- and that's only if you need wireless, i.e., the router has 6 or 7 wired ports, also.
Further, I'm having a problem finding software that'll work with the Netopia device under Ubuntu (that's what I'm doing here :-)
Dec 31, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Reset network key
Are you looking for wep key ?
This is the password of your wireless network.
You will find this on the set up page of the router. for this you will need to access the set up page of the router and check the wireless settings of the wireless router.
If you want to change the key, you can change it on the set up page of the router.
Click here for more information
Mar 12, 2010 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
Wireless adapter
You will need to check the wireless settings of
the router.
wep key is a password for the wireless network.
your wireless network must be secured. You will need to check the wireless security settings on your router.
Is there any computer online using the router.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Feb 05, 2010 | Microsoft Wireless Network Adapter Xbox...
How do I find the WEP Code for my Wireless G Dynex?
The wep key is setup on the wireless router, not the adapter. If you do not have the login information for the router, then the easiest thing to do is reset the router to default settings (this removes any existing keys) and then configure it with a new key. If you reset the router, you will need to connect to the router with a network cable to reconfigure it.
Oct 07, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Cannot get wireless adapter to connect to wireless router
The key number is the passphrase on your router when you initially set it up. Usually you'll need to enter it when you set up a wireless router.
Jan 21, 2009 | Intel Pro 1000XT Server Adapter...
Wireless network
You access the setup screen on a Linksys router by going to http://192.168.1.1 in your web browser. When asked for the username and password, the defaults are a blank username and "admin" for the password. Of course, if you changed them you'll use that information.
On the wireless settings screen, make sure the mode is set to either "mixed" or "G-only".
The default SSID (network name) is "linksys". Change this to something else so you'll be able to easily identify the network when you connect from the wireless computer.
The default wireless channel is 6. From the drop-down list, pick a different one. All Linksys routers start with channel 6, so using a different channel can help prevent interference which slows the network.
Under wireless security, choose "WEP". If your wireless adapter supports it (most do), pick "WPA Pre-shared key" for the mode and "TKIP" for the algorithm. WPA is more secure. (If you really want to, you can disable wireless security. It makes connecting very easy, but then anybody in range could use your network. Let them pay for their own service!)
If you've picked "WEP", enter a passphrase in the box, press the generate button, and record the key that's generated. This will be the key you need to enter in your wireless adapter so it can access the network. (Some adapters let you enter the same passphrase you put in the router and generate the key automatically. If yours does, do that. It's easier than entering the long key value.)
If you picked "WPA", enter the keyphrase in the box. This is what will also go into the wireless adapter.
Save the router settings and close your browser window.
Now when your wireless computer shows you a list of networks you'll know which is yours, and when you try to connect you can give the proper key. Once you've done that, the information is saved so connecting is automatic in the future.
Hope this helps. Your screens may not look the same as mine if your router is a later software version, so some of the terms may be sightly different. But the basic steps and required information will be the same.
Nov 22, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Aug 29, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
495 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Ekse
Thomas F. Schneider
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
