Question about Milwaukee Tool Stanley Hammer Estwing Milwaukee Dewalt Craftsman Drill
When one "Burns out" a
  • 2,176 Answers
It is, however sometimes the cost is the limiting factor. If you give me the model number and brand I can try and find some prices for you. But some of the major tool manufacturers offer a MAX RATE repair that sets the limit on how much it will cost you and they will fix everything. If it is less then you pay less.
Posted on Apr 16, 2011
Hammer drill wont drive
It sounds like the gear inside sheared the teeth. You can check with Craftsman to see if you can get a replacement gear.
Apr 07, 2014 | Craftsman Professional 1/2 in. 8.0 amp...
Hi, I hope both of my problems are related. The chisel is "stuck" and won't release. Also, the unit does not "hammer". The motor runs and when I select drill the unit spins. I...
you need to get that chisel out. If it was hammering with it before the end of the chisel might have broken and not coming into contact with the striker, if it did not then the end of the chisel might be damaged not allowing it to seat fully, either way get the chisel out and put in a regular bit and it will probably work.
Aug 01, 2011 | Bosch 11247 1916" Spline Combination...
Hi, I need the motor cooling fan for my 18v 1/2 " hammer drill...Cat No. is...2602-20 Thanks Lori
ereplacementparts.com
http://www.ereplacementparts.com/
They seem to have any tool replacement part that is available anywhere..
heatman101
Feb 12, 2011 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
My 11236vs drill, the motor runs but the " bit dont turn"
EITHER THE CLUTCH IS SMOKED OR IT HAS SERIOUS GEAR ISSUES, NOT A GOOD TOOL TO TAKE APART UNLESS YOUR FAMILIAR WITH ROTO HAMMER INSIDES, GOOD HAMMER IF PARTS ARE AVAILABLE WILL PROBABLY COST COUPLE HUNDRED TO FIX PARTS AND LABOR!!
Dec 16, 2010 | Bosch Drills
After drilling a hole with a 14" long 1" bit...the drill ceased to work...I've also had the same problem with 2 other drills(both bosch), where one of the 2 doesn't work on hammer anymore because the...
need to check the hamer piston. also if your switch is going out are you useing a long cored (yellow) need a cored rated no less than 15amp 50'. to long burns the switches out ever time. let me know I'll check my manuels. good luck
Oct 12, 2009 | Drills
Motor burned out smoke came from rear of drill. replace motor?
Save the battery and charger and forget the drill. I blieve the motor woul cost you at least half price of new. Go to the dewalt replacement site to find out
Aug 16, 2009 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
No hammer effect, motor work OK
First try the switch for hammerdrill/drill action. If it feels loose, then its internal. if it feels ok, then your hammers on the cage are stuck, frozen or worn.
Jul 17, 2009 | Hitachi DH38YE 1 1/2" Spline Rotary Hammer
Bosch Hammer drill GSB 16 RE doesn't work every time I press trigger
Check the brushes. the switch may have a short. Also, check the wiring from the switch, making sure there is no loose connections to the field. Definitely fixable. Lemme know Please rate me
Oct 04, 2008 | Drills
Milwaukee Tool Stanley Hammer Estwing Milwaukee Dewalt Craftsman Drill Logo
104 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
Harjeet Singh
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
