Question about Sharp LC19SB27UT LCD TV
My Sharp TV started "snowing"
  • 1 more comment
  • maggieluz Apr 08, 2011
    Thanks for your prompt response. Seems like the Digital Main PC since nothing else is working! May have to buy a new TV as there are no repair man here. Thanks again.
    Maggie
    Yes,
  • Jacko Oct 28, 2012
    Same problem as my TV. Please look at my post on 52' Sharp snowy picture.
  • Sharp Master
  • 6,993 Answers
I believe your TV should have other source of input, HDMI, RCA, Component. If you were using any of these connection, try another connection method. (If you were using RCA, try Component).
Usually, a bad cable also causes this kind of problem.... So, apart from your DVD, try a local station or receiver and observe if the will still be snowy. Also, change your cable, in case you are having a bad cable.
If the TV has the same fault even after using other connection method, then it is possible that the TV is having a defective Digital Main PC board. Snowy display is a symptom of defective Digital Main PC board.
At this point you will have to take the TV to a local repairman, because fixing a problem like this requires a specialist.
Good luck.
Posted on Apr 08, 2011
Are blu ray stops payling in the middle of movies for no apparent reason
One of the possible reasons is that your Blu-ray player is unable to read the disc. Check to make sure the inserted disc is clean and not scratched on the playing side. If so clean the surface of the disc or use an alternative Blu-ray disc to verify. ... Only Region B Blu-ray discs and Region 4 DVDs are compatible.11 Oct 2017
Blu-ray Player cannot play discs - Samsung
www.samsung.com/au/support/skp/faq/1045337 blu ray stops payling Google Search
Oct 23, 2017 | Sharp BDHP20U Blu-Ray Player
Tip
Tips to Burn Movies Purchased from iTunes to DVD
It's easy enough to burn a movie or video on our computer to a DVD disc in order to watch the movies on TV via DVD player. But it's not the case when it comes to burn movies purchased from the iTunes Store to DVD. As you need to know, all video files, including movies, TV shows and music videos we got from iTunes are protected by DRM technology, which makes it impossible for us to directly copy the iTunes movies to DVD burner software. But that not means we can't find a way to burn the DRM-protected iTunes videos to DVD discs for watching on TV. In fact, there is a tool called TunesKit iTunes to DVD Converter (http://www.tuneskit.com) will get the job done with ease.
This iTunes video converter application is going to help us bypass the DRM lock from iTunes movie purchases while converting the DRM'd video files to unprotected MPEG-4 format which is supported by most of the DVD burning software so far. Now you can follow the instructions below to easily get rid of DRM from iTunes purchased movies before burning them into DVD.
Here we will take iTunes to DVD Video Converter for Mac as an example. So make sure you've downloaded the latest version on your Mac. Otherwise you should click the URL here:
http://www.tuneskit.com/TunesKitforMac.dmg
1. Load iTunes movies to TunesKit by clicking "Add Files" button or by dragging & dropping action supported by this converter.
2. Select output settings, like the output path, audio tracks and subtitles before converting the DRM-ed iTunes movies to MP4.
3. Start to remove DRM protection from iTunes movie purchases by clicking "Convert" button.
4. Find the converted DRM-free iTunes videos in the output folder and add them to DVD burner to begin burning them to DVD.
Once the movies are successfully burnt to the discs, you are freely to play the iTunes movies on your HDTV via DVD player at anytime you like.
For more tips and tricks of iTunes movies, please visit the official site: Best iTunes DRM M4V Removal Software Remove DRM from iTunes Rentals...
on Oct 27, 2014 | Computers & Internet
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Mar 02, 2010 | Denon DVD-1740 DVD Player
My Sharp 27DV-S100 will not accept DVD discs.
replace the dvd mechanism assembly.usually
runs 60-90 bucks.you can buy the part from
encompass.com.the dvd mech cannot be repaired by individual parts.the entire dvd mech
must be changed and is available.this may
require a technician to repair this depending on
how mechanically inclined you are.the part is
available to the public.
Jul 29, 2009 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
The discs keeps skipping and stopping like the old movie reels
DVD will play and all of a sudden will stop right if the middle of a movie
Apr 12, 2009 | Coby MP-C858 MP3 Player
Player suddenly freezes
Try running a dvd cleaner through it first, before trying anything else (the type that looks like a DVD with a brush underneath).
The regular DVD might have been a fluke (scratches, rental?, burned dvd?)
Was there anything special about the new Blu-Ray Disc - what was the tile? On certain titles, you may need the firmware upgrade found at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300
Mar 07, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sharp LC19SB27UT LCD TV Logo
57 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
