Question about Maytag Bravos 3.8 Cu. Ft. Washer
Leaks at bottom where the 1-1/4" nut is attached.
  • Maytag Master
  • 2,605 Answers
Hello, Welcome to FixYa.
I'm pretty sure I know what you're referring to and in fact I can explain what needs to be done to gain access and repair though it is pretty involved (via removing the tub...it's pretty easy once you see how).
It is most likely the seal under the inner basket (spin basket) and it is a non-serviceable part outside of replacing the complete outer tub assembly as shown here...
If this is a repair you think you can mange let me know, I'll watch for your reply. You may however opt to call a pro. Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Apr 08, 2011
I'd like to learn more about this please. I have the same model and the same problem. There was some obstruction in my outflow hose, and after I drained it things worked better...BUT the problem remains. Sounds like pebbles bouncing around down there and a possible small leak (but that might have been me tipping the unit forward and spilling)
The water in the outflow is blue-ish, if that helps.
We have the "clean washer" alert as well, but since cycle ends at LD it never clears.
I'd like to clear out whatever is down there
Posted on Apr 25, 2011
  • fdurso Jun 05, 2011
    Nevermind - my problem was 22 cents in coins in the outflow pump. It developed cracks and I replaced it. Problem solved.
Hi- 1995 jeep wrangler 2.5yj- clutch grinding won't go into gear - seems full of fluid but over filled it works good for a few months -does it again- repeated -works good-maybe master slave problem ?
1995 YJ if still stock all that is ONE PART, see FSM quote below.
is the fluid dropping, day by day, week by week???
y/n?
yes, then either the slave or mc are bad.
sometimes both can fail, (rust happens inside and is progressive)
what I do , is this. (if not wanting to change out both)
1: look at the MC, if it done leak down either side of the fire wall
it might be good (dont mean the piston seals good but its not leaking, so if fluid drops , (every week say) the the MC is ok
and for sure the slave leaks.
2: so where is your slave. have you looked,? (swaps happen)
most leak and can not be detected as that leak landed on the road to work.
for sure its just 2 parts, here, you know the clutch is ok.
because it works with fluid in the system and bled.
now ILL PASTE THE FSM words out of a real factory service manual.
they are clear.
FSM words, QUOTE:
CLUTCH HYDRAULIC LINKAGE REMOVAL
The clutch master cylinder, slave cylinder
and connecting line are serviced as an assembly
only.
The linkage components cannot be
overhauled or serviced separately. The cylinders
and connecting line are sealed units. Also
note that removal/installation procedures for
right and left hand drive models are basically
the same. Only master cylinder location is different.
(1) Raise vehicle.
(2) Remove fasteners attaching slave cylinder to
clutch housing.
(3) Remove slave cylinder from clutch housing (Fig.
9).
(4) Disengage clutch fluid line from body clips.
(5) Lower vehicle.
(6) Verify that cap on clutch master cylinder reservoir
is tight. This is necessary to avoid undue spillage
during removal.
(7) Remove clutch master cylinder attaching nuts.
Note that one nut is accessible from engine compartment
and one nut is accessible from under instrument
panel (Figs. 10 and 11).
(8) Remove clip securing clutch master cylinder
push rod to pedal and slide push rod off pedal pin.
(9) Disconnect clutch pedal position switch wires.
(10) If pedal pin is equipped with bushing, inspect
condition of bushing and replace it if worn or damaged.
(11) Remove clutch hydraulic linkage through engine
compartment.
Dec 02, 2016 | Jeep Cars & Trucks
How to install quarter window that flips out on 2003 dodge Dakota. 2 door.right side
REMOVAL
(1) Remove quarter trim panel.
(2) Remove the bolts attaching the latch to the cab
side panel.
(3) Remove the nuts attaching the frame/hinge to
the B-pillar.
(4) Remove the glass from the cab.
(5) If necessary, remove the latch from the glass.
INSTALLATION
(1) If removed, install the latch to the glass.
(2) Center the window glass at the opening, insert
the hinge studs in the B-pillar holes, and install the
nuts.
(3) Attach the latch to the rear side panel with the
bolts. Tighten the bolts with the latch in the lock
position and pushing rearward on the latch.
(4) Test the vent window for water leaks.
(5) Install quarter trim panel.
INSTALLATION
nuts.
Oct 02, 2016 | 2003 Dodge Dakota
How do you reattach the factory front skidplate?
It is bolted to the sub frame of the car.
Jun 14, 2012 | 2006 Kia Sorento
Leaking faucet connection
Although it looks like the leak is coming from the hose side, it might still be coming from the swivel nut. Snug it up no more than 1/8th of a turn. If leak persists, snug it again. If still leaking, replace the supply flex.
Mar 24, 2017 | Fluidmaster Plumbing
I am looking for a diagram of the bumper assembly for a 2004 Chrysler town & country.
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
  1. Release hood latch and open hood.
  2. Remove the headlamp assemblies.
  3. Hoist vehicle and support with safety stands.
  4. Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
  5. Remove front wheels.
  6. Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
Fig. 1 133387737
Fig. 2 133387738
  1. Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
  2. Disconnect fog lamp wire connectors, if necessary.
  3. Lower vehicle.
  4. Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
  5. Remove bumper fascia from vehicle.
INSTALLATION
  1. Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
  2. Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
  4. Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
  5. Install front wheelhouse splash shields fasteners.
  6. Install front wheels.
  7. Connect fog lamp wire connectors, if necessary.
  8. Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
  9. Lower the vehicle.
  10. Install the headlamp assemblies.
Jan 02, 2011 | Chrysler Town & Country Cars & Trucks
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
Moen two-handle kitchen faucet, 1990's model installed new a few years ago, is leaking underneath at the center where the spray hose would connect. I didn't use the hose, though. The nut was tight. It...
The nuts used for capping off the sprayer attachment will bottom out and not seal. Unless there is tape or thread compound on the nut, it can spray a tiny jet up under the faucet when the faucet is activated. If there is clearly water leaking from above that, then the o ring for the spigot may be failing and need replacing. If this is the case, it will only leak when the faucet is activated. There is always the possibility of a crack in the casting of the faucet body; hope not:)
Aug 22, 2010 | Moen 7910 Chateau Two-Handle Kitchen...
Need a diagram of the adjustment or tension bolts for installation of alternator on 1995 Ford Aerostar-4L, Front 2 wheel Drive
This is from the workshop manual, direct quote.
Generator, Aerostar
Removal
1. Disconnect battery ground cable (14301).
2. Remove snow/ice shield.
3. Remove engine air cleaner intake tube (9A624).
4. Disconnect generator wiring at the voltage regulator (VR) (10316).
5. Remove attaching nut and wire from generator (GEN) (10346) output terminal.
6. Remove wiring connector bracket.
7. Loosen the drive belt tensioner (6B209) and remove the drive belt (8620).
8. Remove generator brace (10B315) and bolt attaching generator to drive belt tensioner bracket.
9. Remove generator from the generator mounting bracket (10153).
Installation
1. Position generator on the generator mounting bracket.
2. Install the attaching bolts and tighten to 40-54 Nm (30-40 lb-ft).
3. Install the drive belt over generator pulley (10344).
4. Adjust the drive belt tensioner as outlined in Section 03-05.
5. Install wiring terminal and attaching nut on generator output terminal.
6. Install wiring connector bracket.
7. Install engine air cleaner intake tube.
8. Install snow/ice shield.
Nov 05, 2009 | 1995 Ford Aerostar
Water is leaking from the bottom of the freezer door? The water pools at the bottpm then it leaks out
I just fixed, possibly, same problem. Took off nut that attaches water to the fridge in the back, and cut off 2'' and replaced the plastic compression ring. Tighten the nut and no leak. $1.29 for pkg of 3 at HD
May 11, 2009 | Whirlpool GD2SHGX Refrigerator
Maytag Bravos 3.8 Cu. Ft. Washer Logo
229 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
