Question about Cell Phones
I have several Nortel M5316 ( NT4X42 ) telephone sets with a handsfree problem. The telphone functions properly when the phone is in the non handsfree mode. When the telephone is in handsfree mode and I use the volume control bar, the display indicates that the volume is increasing. However, there is no volume increase through the speaker. Any suggestions?
  • slayden734 Apr 11, 2011
    I have used other handsfree phones on this line with no problems with the volume.The lines coming in , the hanset, line cords etc are all working. The problem is with these few sets seems to be with the hansfree function. Any more suggestions??
  • 1,555 Answers
You might have used other handsfree phones also. Kindly let me know the normal voice level in comparison to other phones volume in handsfree mode. The strength of volume can be devided in 1-5 as 1 the least volume and 5 the loudest. Depending upon that only I can tell you the solution.
Posted on Apr 09, 2011
Norstsar M7208 Corded phone cannot use handsfree feature
Your problem is in the phone system programming. I would need to know how old your main cabinet is in order to tell you how to fix it. On most Nortel systems you use "Feature Key" **266344 (Feature **CONFIG) . You will need to program from a M7310 phone because you need the 3 soft keys under the display which the M7208 does not have. The top 4 keys on the phone are used for programming (2 LEFT & 2 RIGHT) . I'm referring to the 2 vertical rows of keys (5 LEFT & 5 RIGHT). Upper left key is up a menu, upper right key is SELECT, lower left is BACK, and the lower right is NEXT. I believe you need to find the CAPABILITIES menu for your station/extension and use the next button to look for the handsfree setting use the key under the display to change it. The manuals are at http://wedophones.com/Manuals/Nortel/
Aug 30, 2014 | Nortel Norstar M7208 Telephone
Trying to change the number of rings before my phone goes to Voice Mail on the Meridian (Nortel) M5316. Only two rings currently so I miss a lot of calls. Thanks!
Depending what system your provider is using it can either be done by you at home or they will have to set it. If you call your provider they will help you or they will fix it. Each ring is set at 6 second intervals so if you have 3rings that is 18 seconds. If you was 6 rings then ask for 36 seconds etc. hope this helps
Oct 11, 2013 | Aastra Telecom Aastra MDC Centrex...
Does the phone run on batteries
The phone can get some power from the loop like a basic telephone. That should suffice to make phone calls.
But many of the advance features and display options cannot work on loop power alone. You have to get a special plug that plugs into the wall AND the phone jack. Then plug the phone into that.
I am not aware of any battery in the phone.
Aug 08, 2013 | Nortel Aastra M5316 Meridian Digital...
I've lost my user manual and I need to reset the date and time.
I lost a user manual, then found this site called find my manual. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Jul 14, 2010 | NorStar Aastra M5316 Phone, NT4X42 (Un,...
Very low volume on 'handsfree' option; whereas the vol. for the line button can be quite loud
Hi.
The Volume function of that phone is controlled by the up down vol button on the phone. the only time it does anything is when that function is being used. ie. when you have the handset in hand the vol buttons control the handset volume, while the phone is ringing the buttons control the ringer volume etc.
Dan
Oct 09, 2009 | NorStar M5316 Phone, NT4X42 (Refurbished,...
M7324 nortel phone line 1 can't answer on handsfree, how do I fix this?
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
Sep 16, 2009 | NorStar M7324 Telephone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Can't use handsfree
Please contact your local Nortel vendor to reset and program your phones
Mar 19, 2009 | Lands Phones
Nortel T7316E, How to make headset work ?
Look in the System coordinator guide 5.0 for HandFree
Select type of handfree
You must set the Handsfree at: auto
Its in the deep programming
Your going to need Business Series Terminals programming overlay to put over the phone.
  1. Press Function **266344
  2. Than enter system coordinator pass word
  3. Press SHOW once and enter your phone extension number
  4. Press SHOW twice
  5. Press NEXT tree times
  6. Change the parameter at HANDFREE with MOD
  7. Set it at AUTO
I beleved this will FIX it OK!
Jan 28, 2009 | Lands Phones
Cell Phones Logo
94 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
