Question about Maytag Washing Machines
I have a maytag commercial washer/dryer stack unit.Model number is mlg19pnaww. It was working fine then it was left unplugged for about 1 week. when it was again plugged in there is no readout at all on the screen.I can get both washer and dryer to go into self diagnostics mode and run by depressing the access switch closed which produces an F5 code. my question is : is the electronic board bad if the screen is "blank" when power is reestablished or do I need to reset the electronics. (this machine is used at no charge to the user.) My dilemma is I have no literature other than the wiring diagram available so if there is need to set access codes,etc. I am at your mercy for a solution.
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
vest6
  • 196 Answers
SOURCE: Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Posted on Jan 15, 2008
SOURCE: Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Posted on Jul 24, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher & Paykel top load intermittent running
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Posted on Dec 15, 2008
SOURCE: Program computer-Maytag commercial washer mat12pdbaw
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Anonymous
Posted on Feb 23, 2011
Maytag washer does not spin
What is the complete model number of your unit?
Dec 07, 2012 | Maytag Neptune MLE2000A Front Load Stacked...
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
Maytag washer filled with water then stopped working.
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Whirlpool stacked washer and dryer
unplug unit then wait 1 minute and replug..if still lock out replace control board
Jun 27, 2008 | Whirlpool LTE5243D Top Load Stacked...
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Jan 04, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
