Question about Keys Fitness KF-T2.0 - Treadmill
The walking belt on my keys healthtrainer 2.0 does not want to stay centered and moves to the right, hitting the edge at times.
  • 95 Answers
Here is a tutorial on how to adjust a walking belt, although I would also search on youtube for visual instructions.
Posted on Apr 08, 2011
Testimonial: "good info"
Consol on nordictrack T9.1 has error code 58 when I switch it on then it goes in to a loop of the preset programs but you can't select them
follow this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Oct 03, 2013 | Nordic Track Exercise & Fitness
Belt is skipping
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jun 13, 2010 | Proform 325 Treadmill Walking Belt
Losse belt, how to tighten?
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes.
May 20, 2010 | Nordic Track Exercise & Fitness
Belt is slipping when i walk on it
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 17, 2010 | Icon Image 17.5 S Treadmill
Belt problem
f the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD.Using the hex key, turn both idler roller bolts clockwise,1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 14, 2010 | Proform Sport 1000 Folding Treadmill...
How do you adjust the slack on the belt? This is for a 815 model.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 04, 2010 | Schwinn 820 P Treadmill Silver Service...
How do you adjust the belt on a PROFORM,( Model #
Unplug unit then, using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 21, 2010 | Exercise & Fitness
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
How do I repair the seam of the walking belt? There is about a 5" wide seam on the walking belt and one end has come undone (about a 1/2 inch. It catches each revolution & I'm afraid that it is going...
Be extremely careful when trying to trim a belt. Understand that many hazards exist when performing these steps that can result in serious injury. If you have any question whether you can perform these steps or not, please call a professional and do NOT attempt this repair.
There are two methods that can be used to trim a walking belt when it has developed a tattered edge:
1) Remove the belt from the treadmill for trimming.
a) All walking belts are cut at some point during their life, whether in manufacturing or later during service, so this will not compromise the integrity of the belt as long as you cut a straight line and do not leave a rough edge.
b) Remove the walking belt from the treadmill, lay the belt flat and even on the ground, and measure and equal distance on each end of the belt and mark the belt for cutting on each end of the belt. Cut no more than necessary to restore a smooth edge.
c) Use a piece of flat steel or other metal object that is straight and long enough and connect the two markings on the belt with the metal object.
d) Using a new razor knife, box knife, or similar instrument, cut the belt along the steel object. If the knife has a new edge, you should cut through the belt in one or two passes of the knife.
e) Check the belt for a smooth edge and reinstall the belt.
2) Cut the belt while it is mounted on the treadmill. This method should only be considered by those who are familiar with treadmills and very good with tools. This can be a dangerous process.
a) Track or center the belt off center to the opposite side of the tattered edge (i.e.- if the belt is tattered on the right side, track the belt off centered to the left side by about 1/2 to 3/4").
b) Operate the treadmill at a very slow speed. Usually 1.0 or 1.5 MPH will be sufficient.
c) Using both hands, line a new razor knife up on the tattered side of the belt. Make sure to cut no more than necessary to make a smooth edge.
d) With the belt moving and using both hands, lift the knife up and contact the belt making sure to hold the knife steady and keeping your hands and clothing as free from the moving roller as possible. You will not damage the roller to the point where it will hurt the operation of the treadmill.
e) Do not lower the knife until you see the belt separate from the tattered edge. Once this happens, turn the treadmill off, unplug the treadmill, and cut the tattered strip off the treadmill.
f) Track or center the belt and operate normally.
Feb 13, 2010 | Proform 730 Folding Treadmill Model...
The Walking Belt keeps staying close to the right side
speed the belt up to around 4mph while adjusting the belt. you will see it centre very quickly. once centered leave it to run for a couple of minutes to see if it stays central.
Apr 16, 2009 | Reebok New York Giants Eli Manning Jersey
Keys Fitness KF-T2.0 - Treadmill Logo
158 people viewed this question
Top Keys Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Keys Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
