Question about Nikon Cameras
I have a Nikon D70. All of a sudden, when I insert any of my memory cards, my camera indicates they are not formatted. I have attempted to format them using the camera but it does not work. Please help!!!
  • 667 Answers
Time to shine a light into the card slot and check the pins. You may have a bent or missing one
Posted on Aug 08, 2008
I have an early 2004 D70 and am receiving random digital display errors of FEE, CHG, FOR. If I play with removing and reinstalling the battery or memory card they will usually clear but I cannot figure...
Okay the FEE is telling me that you haven't locked your lens in at F22. Lock the lens should be an aperture ring turn it to the smallest aperture and there is a little lock on the side of the lens that will hold it in that position. The camera then looks after the rest. If this is allowed to float then the camera is getting a faults input from the lens. The CHG is a card error, possible you have been deleting images from the card and not formatting the card the card needs to be formatted to the camera.
As a rule of thumb format the memory card in the camera after each time you download pictures to the computer. This cleans the memory card and allows proper communications between memory card and camera. Okay you'll love this one the "FOR" error is a known problem with Nikon D70 and can be fixed by updating your camera firmware on Nikon's site that Otta help. cheers have fun
Jan 13, 2011 | Nikon D70 Body Only Digital Camera
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon d70 keeps popping up with "CHA". Wich means
You could try formatting in on PC by right clicking the card's icon in My Computer to bring up the options, then format it on the camera as well
Dec 16, 2010 | Nikon D70 Body Only Digital Camera
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Feb 05, 2010 | Nikon D70s Digital Camera
My NIKON D70 has trouble with flash cards larger than 2 G.
The D70 has known issues with certain cards / capacities. Nikon has identified the cards and capacities that are guaranteed to work with the D70 specifically, on their page dedicated to this info linked below:
http://support.nikontech.com/app/answers/detail/a_id/9601
It seems that only Lexar and Microdrive cards that are 4Gb are supported (some with significant limitations) and no card greater than 4Gb is supported at all, regardless of manufacturer.
Oct 10, 2009 | Nikon D70s Digital Camera
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
Jan 30, 2009 | Nikon D70s Digital Camera
Digital Nikon D70S - memory card removed while turned on.
Hi - You can download the manual by clicking the link underlined in blue below:
Nikon > D70
See page 200:
Try resetting the camera in this way first to see if it clears the problem.
The -E- means that the camera cannot detect that a memory card is present see page 199.
Check that the card is properly inserted (page 20) and as a last resort try formatting it (you will lose any pictures on it):
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 22, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Nikon
The cards may have been corrupted in some way. Have you tried them in another camera or a card reader? If you have a reader, you might want to try formatting one of them from your computer.
Jan 10, 2008 | Nikon D70 Digital Camera
Cameras Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
