Question about Weber Genesis Silver B Grill
Gas only leaks out to grill. Can't get grill hot enough.
    Problem Solver:
Turn gas off
Check all orafices make sure they are clear of any debris.replace burner assembly turn gas on turn dial 1/4 turn or so.lite burner with matxh or elwctric
Posted on Apr 08, 2011
What is the life expectancy of a gas grill pressure regulator?
I've been in the propane business 28 years and have found regulators from the 1950's still in use today. Regulator manufacturers tell us they should be replaced after 25 years. It should typically outlast the grill itself, which often require new burners, cooking grids, etc. The hissing sound can just be the flow of gas thru the regulator. If you smell gas however, then you should replace it. If it is affecting the pressure to the burners and not getting hot enough to cook properly, then replace it as well.
Jun 06, 2015 | Weber Genesis Silver B Grill
Not hot enough
Check that the gas jet is not partially blocked limiting the amount of gas out. To up size my bbq to a hotter flame I used oxy welding set tip drills and gently opened up a size. worked a treat and cooked quicker. maybe you can get next size jets for your problem. check that the regulator is not restricting the gas flow.
May 28, 2013 | Fire Magic Grilling
We have permasteel gas BBQ grill. grill can be lighted up, but gradually died off. It seems that no enough gas pressure and flows. The regulator gets iceing and cold.
too much gas passing from reg causing freezing of gas reg or line or check for gas leak on reg , reg could be stuck open again too much gas pasing .
Jul 04, 2012 | Thermos Stainless Steel Gas Grill
My grill is burning low it will not get hot enough. I leak checked and there is no leaks.
take it part on inside and clean real good . All parts should lift out. Also you can put a new burner on the bottom of your grill. They sell new burners at Walmart home depot and lowes good luck
May 20, 2011 | Fiesta Blue Ember Gas Grill
E790 FIRE MAGIC NOT GETTING HOT ENOUGH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 01, 2010 | Fire Magic Echelon E790I-2A1N Stainless...
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
GAS JETS BLOCKED IN OVEN
If there is only enough gas for the pilot, it is very likely the main gas ciontrol valve is either in need of replacement or the "hot wire" sensor is in the wrong place or broken.
Basically the hot wire determines if the pilot is lit before turning on the main gas supply valve. It is a safety feature to dissapoint the suicidal.
I suggest this is fitted by a gas engineer as a leak at the valve can be very dangerous.
Feb 09, 2010 | Kitchen Ranges
Grill will not light
Try replacing the regulator if you get no gas flow, or very weak gas flow. If you have gas flow and you are trying to light the grill with the ignitor. The rotary piezo ignitions must click with each turn, if they don't then they are bad and need to be replaced. If you have a new lynx with the glow plugs, check to see if they are glowing, if they are glowing and the grill has gas and still won't light, then the glow plugs are not getting hot enough which means you are leaking current somewhere and have to trace everything down to find the short.
Dec 22, 2009 | Lynx Grilling
Weber Genesis Silver B Grill Logo
151 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
