Question about Jack Lalanne Power Juicer 250 Watts
I dont now how to clean the basket, - Jack Lalanne Power Juicer 250 Watts
Use a stiff plastic bristle food quality cleaning brush. Scrub under hot running water. Can also use this to clean blade.
Posted on Apr 08, 2011
Ican not remove the the basket for cleaning is to hard
You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Feb 16, 2011 | Salton JM411 Juiceman II Elite Juicer
Have just bought a secondhand Ruby and replaced the blades and basket - still having problems with the basket collecting pulp (apples) and becoming noisy - unbalanced I assume. When I clean out the basket...
Hi Kathy, we had the same problem. You need to soak you basket overnight (every day) in a chlorinated solution/detergent. This will keep your filter basket clean. Also, make sure you rinse out your juicer if you know you are not going to use it much for a few hours as the pulp will dry up and clog your filter. Since adopting we started doing this we haven't had any more problems.
Feb 13, 2011 | Nutrifaster Ruby 2000 Juicer
How do you take it apart to clean it ?
It's really easy, you take down the metal bar and the top comes off, then you should see the orange mesh basket which is removed using your little tool - it's like a key which you turn to remove the basket - rinse under the tap - piece of cake.
Mar 15, 2010 | Jack Lalanne Power Juicer (Stainless...
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
How does it come apart for cleaning
The hot water did work for mine. Here is the solution I discovered:
After removing the food plunger and juicer cover: (1) Unscrew the 3 screws that hold the cutting blade plate in the center of the basket and lift off the cutting blade plate; (2) Unscrew the base counterclockwise (it will unscrew from the threaded center piece) and lift it up; (3) Lift off the basket and juice bowl. Now you can clean the basket and juice bowl.
Sep 20, 2009 | Juicers
Unable to take juiceman apart to clean
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Tom
Jan 25, 2009 | Salton JM411 Juiceman II Elite Juicer
Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Cleaning my juicer
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls. Now I rinse the little ball bearings really good after using and dont store it connected. Then before connecting the basket to the juicer rinse the little bearings and push them in to make sure they are freed up before each use.
Tom
Mar 23, 2008 | Juicers
Jack Lalanne Power Juicer 250 Watts Logo
64 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
