Question about Kenmore HE2 Plus Front Load Washer
I have a Kenmore he2 plus it was washing a load and was in the spin cycle when i came back the washer was off the door is still locked and it will not turn on i unlocked the door with the release on the door lock unplugged the washer and plugged it back in it still will not turn on what can i do to fix it
  • 5 more comments
  • chamm91 Apr 08, 2011
    the outlet has power and i have power coming to the control unit on the upper left side of the unit but i do not have any other test info to check any thing elts my guse is that it had a power spike and burn out one of the 3 control units i just need to know whitch one so i can replace it and i do not want to guse at it because they are about 200.00 each
    the outlet has power and it has power to the control unit on the upper left inside panel of the unit my guess is that one of the 3 control units got a power spike and burned it out i just need to know how to test them and find the faulty part because they cost about 200.00 each and i don't want to guess and hope i get it right my luck i will end up buying all 3 because it won't work with the first 2 and i can buy a new one for that price
  • chamm91 Apr 09, 2011
    are you talking about the timer above the soap dispenser? and how would i re time it ?
    i have 120v on the 2 pink wires going to the control unit did not test any other wires because i don't know what i should have for all i know it could be just the power button i just need a way to test the stuff
    are you talking about the control unit on the upper left inner panel that the front control panel is connected to i did not hear any click from any of the control units
  • chamm91 Apr 10, 2011
    I do not have a knob with a timer it is all circuit boards and a digital display for the timer I can bye the front control panel the control unit on the left upper inside panel and the control unit on the lower left inner panel do you have a way to test the control units so i can order the correct one
  • chamm91 Apr 13, 2011
    can you send me a wiring diagram for the washer so i can test the control unit and front control
  • 4,323 Answers
Hi
This seems to be an issue with the control board or timer clock. You would need to disassemble the panel to access the timer clock. Use a multimeter to test the timer/clock, set the multimeter to R x 1 scale. Locate the clock motor leads, label them and remove them from the circuit. Place a test lead on each clock motor wire; there should be continuity. If not, replace the clock. Test for the continuity of the switch contacts when the start and stop knobs of the clock (of some models) are pushed in and turned, and when the knobs pop back out. All these tests should show continuity. Hope this helps... Please post back if you need more information.
Daniel
Posted on Apr 10, 2011
  • Daniel Scott
    Daniel Scott Apr 10, 2011
    Alright....post back for further assistance
  • 4,399 Answers
Thanks for choosing Fixya and welcome. Does the washer have any power at all?
Posted on Apr 09, 2011
  • 5 more comments
  • Richard Hale
    Richard Hale Apr 09, 2011
    You need to make sure to check the fuses and breakers on the washer. Make sure that the lid is closed firmly. If the lid is not shut all the way, it can cause the washer to not work. It may be your lid sensor or latch that is bad. Also, make sure the washer is not out of time. You might want to make sure it is on the right cycle. If so, it can cause your issue.
  • Richard Hale
    I am talking about your actual setting. Sometimes they can get out of time and it can cause the washer to not respond. You want to make sure it is set correctly on one, or first wash. It is your timing setting. This is what you spin when you first start the washer. Even if it is electronic, it can still be the problem.
  • Richard Hale
    All you would be doing is making sure it is on the correct setting, which would be first wash. I didn't see the response about the mother board. Which wires are you testing on your board?
  • Richard Hale
    I am going to look at the wires. Give me a second please.
  • Richard Hale
    Here is a simple test for the ccu. Unplug the washer and plug it back in again. You should hear a click when you plug it in. If you don't, it is bad.
  • Richard Hale
    Richard Hale Apr 10, 2011
    Sorry for the late reply. I just came back from work. That is the one I am talking about. You should hear it click when you plug it back in. If it doesn't click, that is what needs replaced.
  • Richard Hale
    That should solve your problem. Once again, sorry for the late reply.
  • 2,382 Answers
Hi, plug something else into the same outlet to verify you have power there. If the other item doesn't work you have a popped circuit breaker or blow fuse.
Check the cord, perhaps you have a defective cord that can quickly be fixed.
Posted on Apr 08, 2011
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
My kenmore he2 front loader is not going threw the wash cycle, but all the lights come on and the door is locked what could be wrong?
Hum may have a bad water pressure switch? It detirmines when the wash cycle should start according to the water level. if bad it will not signal the appliance to start washing. Also may want to check ur door lock switch if its bad it wont go into wash either.
Sep 19, 2014 | Kenmore HE2 Plus 3.6 cu. ft. Super...
My he2 kenmore clothes washer does not go into spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine will not turn on it shut off
Have you tried unplugging the unit and waiting for a minute and then plug it back in. The load might have been off balance and caused that condition. Once it has been reset you might be able top end the cycle.
Dec 07, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
59 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
