I am not sure what fuse to put in it, when I got it it had a 500 MA Ceramic 5x 20 250v Fuse blown; but when I replace it with the same it automatically pops. The board of the power supply has written on it that at F1 should be a 8.0 AH/250V Fuse. What fuse is it supposed to have, so I can replace it? Thank you Corey
  • 635 Answers
On the body of the fuse or on the circuit board there will be a suffix T or F next to the value.
T stands for Time delay or slowblow. If its marked F it means fast acting fuse.
Now after replacing the correct fuse if it still pops you have a short circuit and it is drawing high current, so the popping. Get professional help or you will do further damage.
Posted on Apr 08, 2011
The fuse inside was blown and on opening found the blown fuse broken. replaced it and it is working. however the blown fuse was smaller in size while we replaced with a bigger size. does it matter???
you must replace the FUSE with the same capacity for example: you will see in the metal fuse the incription 240vac-15amp see if the fuse is Ceramic or Glass, you CAN not use 125vac,10amp or 20amp, the circuit WILL not protect the electronic system, and will dammed another section. Please rectify this INMEDIATELY.
God bless you
Jul 31, 2012 | Microwave Ovens
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse blown on Europower PMP 3000. Where can I find a 10 Amp 250 V ceramic replacement fuse?
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Jul 05, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
How to change the fuse on Kitchen Aid model KEMS308SBL02 combination oven and microwave. The oven door locked after a power outage this week and now the oven won't come on.
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Dec 04, 2010 | Ovens
Treadmill keeps blowing fuse
I can't solve your problem cause I am haveing the same, But i lost my fuse on the way to get a new one can you tell me what the fuse is? Volts? MA? All that?
Jun 14, 2010 | Exercise & Fitness
Still operable
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Jul 30, 2009 | Goldstar MA-1011 Microwave Oven
Microwave Fuse
you can use any 8 amp fuse of that caliber even a bit larger if you had to.
Phil
Apr 14, 2009 | Daewoo KOG-867T Microwave Oven
Possible fuse -- no power
Replacing a fuse Locate your fuse. Most microwave fuses look like the one pictured to the left. They are usually an inch or two long. Each end is metallic and the center is either ceramic or glass.
To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Decide if your fuse is blown. A blown glass fuse will produce flash burn marks on nearby surfaces, or it will be completely black on the inside. The internal fuse wire (filament) will be melted and blackened. Ceramic fuses give no outward signs of having blown. To determine if a ceramic fuse is blown, test it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is fine. A reading of infinite ohms means your fuse is blown.
Replace the blown fuse. Pop it out of its holder and snap in a new one. You can squeeze the fuse clips together with your fingers in order to tighten their grip. Replace the unit's outer cabinet, plug it back in, and test to see if it is running properly. DO NOT run the microwave with nothing in it.
NOTE: Fuses do not usually blow on their own. A fuse may blow because of problems with the interlock switches or with high voltage circuitry. It is also possible, though rare, that a power surge will cause a fuse to blow.
Jun 05, 2008 | Amana RCS 10D 1000 Watts Microwave Oven
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
