Question about Zanussi Washing Machines
My Zanussi Jetsystem 1600 washing machine would not go through a full wash cycle. could some one tell me what the problem?
    Brigadier General:
  • 6,277 Answers
Sorry, don't know your particular washer but try this and no promises!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
Zanussi jetsystem 1600
Get all of your towels. That little square on the bottom there. Open it with a flat head screw driver. There's going to be a trap there. Unscrew the lint trap by twisting the filter counter clock wise. Be warned, this releases the water. Check to make sure that trap isn't completely clogged with stuff. Put the trap back in tight and properly make sure the tub holds water before putting the square plate back on. ; ) . Voila
Apr 27, 2013 | Washing Machines
Zanussi jetsystem turbodry 1600 wjs1665 w is not heating the water
More than likely the heater element has failed.
This is located at the rear of the washer drum.
It means removing the rear half of the cabinet to access it.
Mar 29, 2010 | Zanussi ZWF1430W Front Load Washer
Error code 40
call AAA washing machine doctor on 0863949848 or visit aaawashingmachinedoctor.com
Mar 02, 2010 | Washing Machines
Zanussi jetsystem 1000 will not do anything
zanussi jetsystem 1000 has stopped spinning the wash ! its missing out the spinning program help ?
Oct 09, 2009 | Zanussi FJS1225W Front Load Washer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Feb 17, 2008 | Washing Machines
Zanussi Jetsystem
scrub above the soap tray to make sure the holes are clear if they are you may have a system where the fab condit water valve is u/s.
May 18, 2007 | Zanussi IZ161S Front Load Washer
Washing Machines Logo
374 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
