Question about Broan-NuTone Broan Rangemaster 61000EX Ballista Wall Mounted Chimney Style Hood (Requires Exterior Blower)
My broan rangemaster 6100 series chimney hood has a problem with the lights - they don't turn on - I've replaced with new bulbs a few times and still nothing....
    New Friend:
I have a rangemaster 6100 series, where the motor blew,where can I get another one? Thank You
Posted on Jan 21, 2017
  • 1462 Answers
SOURCE: rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
Posted on Jun 03, 2007
SOURCE: Broan Allure II
my range hood lights would only work on highest setting. nothing on low or medium setting. fan working fine. I tripped the breaker off then on again at the electrical panel and behold, everything works perfectly fine now. don't know why it worked but it did!
Posted on Dec 02, 2007
SOURCE: Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Posted on May 14, 2008
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: how do I replace light bulbs in a rangemaster hood
Just done it myself. Take both screws out to lift light down from hood. Put your finger either side of bulb and just slide it out.
Posted on Feb 23, 2010
I have a Best K41-1 and my variable speed on the blower does not work. It only works on high speed when slid into that position. What could be the problem?
I have the same problem (again) but with the lights not working also so something else is going on. The usual fix for the fan on high issue is to replace the switch assembly (SB06105117). It's an $80 part. This worked for me the first time it happened. If you are handy then it's a 1/2 hour project - turn the power off at the breaker.
Mar 18, 2012 | Broan-NuTone Best by Broan 30quot; 500 cfm...
Need a elec motor for my rangermaster hood
There are a bunch of those series hoods... need to know the exact model number....
But...
Here are the parts for those hoods and there are motors for most of them...
http://parts.broan-nutone.com/broan/Shop?Dsp=30000&OFFSET=144&PCR=1:1000
heatman101
Jan 10, 2011 | Rangemaster RM60000 Broan Pro Style Wall...
42" Allure II Broan Range Hood I put a new bulb to replace
Get two new bulbs and install them. These bulbs are exposed to a lot of heat above the stove and the filaments get brittle. I suspect that the filament on the bulb that still worked broke when you were screwing it out or back in. good luck. please rate my answer. thanks noreen.
Feb 03, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Broan kitchen hood - frenetic chimney
It can be 2 things.
1. The motor that elevates the fan is turning a tad to much. Just by stepping on the floor near it could cause it to go up/down constantly.
2.Or what i had seen was the wires that go to the switch dont have enough slack, and are just making contact to the switch causing it to think somone is pushing the button constantly.
There is way too many steps involved to type out.
Dec 01, 2008 | Broan-NuTone Rangemaster RMDD3004...
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Controller failed when a bulb blew
Control Board: Part # R111638 = $110.00
I do service calls for Broan-Nutone
Inventex Inc
Nov 12, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Rangemaster cooker hood. model no.LEIHDC120SC/
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Broan-NuTone Broan Rangemaster 61000EX Ballista Wall Mounted Chimney Style Hood (Requires Exterior Blower) Logo
165 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
