Question about Maytag M7DH45B2A Dehumidifier
The compressor will not kick in It will start up and try but will not run Fan continues to operate Almost sounds like the compressor motor is binding trys for about 2-3 seconds and shuts off fan will keep going
    Novelist:
  • 116 Answers
The condition you describe usually indicates that either the compressor is working too hard and drawing too much current or the start relay is gone bad. The noises that you hear may just be a safety shut-off within the relay. A good place to start is changing start relay for the factory recommended one. you will have to access the compressor compartment to see this.
If the standard relay does not correct the problem, there is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your dehumidifier first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system or a faulty compressor. Outside of this may require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a refrigerant leak.
Check your owners manual before making any repairs or modifications to your refrigerator. And there may be an extended warranty on the sealed system and compressor if needed.
Posted on Aug 06, 2008
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 03, 2011 | Goldstar DH504EL Dehumidifier
Compressor runs and gets hot but fan will not kick on. Replaced the capacitor and that did not help. One side of coils gets hot, the other side gets cold, which seems normal. Just can't get the fan...
Don't run the compressor for any length of time without the fan operating. Is it possible that the fan must be replaced? Can you power the fan safely to test it?
Gary
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
Compressor and fan both kick on when starting. Frosts up (normal for this time of year) but then compressor stops but fan continues to run but compressor does not start up again....
From what you have described, it sounds like the defrost sensor may be bad. However, if you're operating the unit in a temperature of 40 degrees or lower. That's the problem. If in a basement application, keep in mind the floor temperature is lower than the air temperature.
Also, cleaning the air intake filter on a regular basis will help.
Hope this helped you. Please let me know.
May 16, 2011 | Edison 40 Pint Dehumidifier
Fan stopped running but it sounds like the compressor is still trying to operate.
Eather the fan motor is going bad or the cap is try changing the cap first, if not the motor.
Jul 17, 2010 | Kenmore 54701 Dehumidifier
No water in the bucket
You most likely have a freon leak, or the compressor is not running. When the machine first turns on you should be able to see if the compressor is running or if it is just the fan. If the compressor is not running it does have a start devise and a relay on it that can be replaced. If the compressor is bad, most units have a 5 year warranty on the compressor, so contact the manufacturer for warranty service. If the compressor is running you have a freon leak, and it would need to be found, repaired and the freon replaced. This is a large repair, estimated charge for a leak repair would be around $149.99 The reason is the long time it takes to find the leak, and all the parts needed. Drier, valve, freon, etc.. Good luck, and I hope it is only the relay. You can get those relitively inexpencively. 3 in 1 kits are also good for a hard to start compressor. They give the compressor a little more kick to start it. They are about $28.00 and easy to install once you are to the compressor. I hope this will FixYa.
Mike
Sep 27, 2008 | Haier 45-Pint Dehumidifier
Kenmore Dehumidifier
My Kenmore had the problem of the fan running, but not the compressor. The compressor overload part was bad.
Togarba
Aug 27, 2008 | Dehumidifiers
Fan doesn't run on kenmore 5230 dehumidifier
sounds like the fan motor is bad most are not repairable new ones about 50$ dan
Jul 14, 2008 | Dehumidifiers
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Haier HDN455 dehumidifier fan runs continuously but not compressor
First ! you are trying to use this dehum in cold weather conditions. this time of the year there is little humidity in the air. best conditions for the dehum to work will be when the temp. is 65 degrees or high, and the humidity is 60% or higher. if you don't trust what I said then take it to sears to be checked out.
Dec 22, 2007 | Haier HDN455 Dehumidifier
Compressor won't run
the over-current relay is tripping out the compressor motor to prevent excessive current through motor windings. To prove this theory, open unit, find motor wires, disconnect wires from unit, and apply 120VAC to motor using external circuit-breaker source. Run 2 minutes max. If motor continuously turns, then relay is failing. Find it by tracing wires back to source and finding a small rectangular item. If motor again quits after 2 seconds, then this motor has an internal over-current self-resetting fuse that may be doing its job of preventing an electrical overload from a dead (shorted) motor.
Jul 07, 2007 | Whirlpool AD40USR Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
393 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
