Question about Intel Computers & Internet
I have a intel motherboard D845GRG and I need cmos repair or bios repair whit flopy disk. can you help me please
    Brigadier General:
  • 3,917 Answers
Hi
Please check this article to repair your bios/cmos:-
http://www.wikihow.com/Repair-Bios
http://www.ehow.com/how_5547892_fix-cmos-battery-failure.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 08, 2011
No video at all, no boot, unable to get bios boot setup, green light comes on but no boot, even with a FDD boot disc. Disconnected HDD and inserted boot FDD, no joy. M/B Asus A8V
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
I am not getting display. why?
Jan 23, 2011 | Asrock P4I45GV...
The motherboard won't give a response
Jan 20, 2011 | ASUS P4R800-VM Motherboard
I need motherboard drivers for intel D845GRG model
Intel Download Center. You'll need to select the Operating System you are using. Good luck
May 15, 2010 | Intel D845GRG Motherboard
I NEED MOTHERBOARD DRIVERS FOR INTEL D845GRG MODEL
Please click here which you can download the Intel D845GRG Motherboard driver.
In the web page, click the download link as shown in the Picture below.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 27, 2010 | Intel D845GRG Motherboard
Intel D845GRG Motherboard Problem:usb wiring conection to board
Hi mrm291048,
The Intel D845GRG MB supports USB 2.0 & is backwards compatible to USB 1.0
For in-depth description of motherboard wire color & location click on this link & scroll down till you see, "Standard USB Cable Wiring Color Code". http://www.usbman.com/Guides/BelkinMotherboard_cable_assembly.htm
You'll also need to open your manual to page 68 If you need the manual for the D845GRG MB click on this link; ftp://download.intel.com/support/motherboards/desktop/D845GRG/BVRG_English.pdf
Between the two you should be able to set the correct colored wire up to its matching pin on the MB.
If this is not answering your question, please set me strait & rephrase the question.
Mike
Sep 30, 2008 | Intel D845GRG Motherboard
Processor upgrade
Dear Friend..
Yes, You can upgrade your system with a new Intel Pentium® 4 processor 2.8 GHz, 533 FSB , but only with the BIOS update. Make sure you have the bios version P06 or greater. See the link below:
http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-009954.htm.
If a get a new processor as above, do not forget to update your bios with the the utility available on intel's site.
I am sure, this helps you. For any additional help, you can ask me..
Aug 16, 2008 | FIC AM 37 Motherboard
Mouse not working after BIOS upgrade on Intel D845GRG motherboard
use usb mouse
othervise re format yours whole system low level
and re install win xp or whataver you want
Dec 14, 2007 | Computers & Internet
GA-G31MX-S2 Motherboard
try changing your CMOS Battery the CR2032...
Oct 28, 2007 | Intel Motherboard
Computers & Internet Logo
209 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
