Question about HP L1940T 19" LCD Monitor
The monitor does not give any view. When I turn off power and turn it on again the monitor lights up but in a few seconds the computer picture is gone again. When I connect anothe monitor taht one works perfect. The problem came up suddenly after a few years of perfect working. Is there som kind of solution? Many thanks in advance.
    Guru:
  • HP Master
  • 1,705 Answers
You've worked it out, just don't want to see the result. Your monitor has bitten the dust. This is fairly typical of capacitors in the monitor power supply failing.
They can be replaced so long as you're good with a soldering iron. You need to look for capacitors on the circuit board which look as though they bulging, especially at the top. Or yellow staining on the circuit board under the failed capacitors. If you can't spot them, then you need to measure them with a voltmeter.
Posted on Apr 08, 2011
Picture won't display after a few seconds
this is either the flourescent bulbs are going out or the power supply has bad capactors on it. You might open it up and look at the power supply board for capacitors with their ends that look like they are "erupting" on the ends.. this means they need to be replaced.
May 13, 2014 | Envision EN-7410 17" Flat Panel LCD...
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Monitor is going off after a few seconds the power led is glowing
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the monitor, this will solve the problem and will never experience such thing again.
Take care.
Jul 18, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Iimj9 sonic tft - lcd monitor goes out after 3 seconds
You should remove power for a few min then hook up and try again.electronics sometimes need to be reset after any fluctuation in power. Good Luck
Jan 26, 2009 | ViewSonic VX910 19" LCD Monitor
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
HP L1940T 19" LCD Monitor Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
